Cycles fails with external EXR containing Z-depth, works if packed though
win64 i7 gtx titan
blender-2.70-b179647-win64
Fails for both CPU and GPU
The plane fails to render, shows in pink.
This is a bit tricky because:
#1. if the .exr file is packed into blender then it works. So I am attaching the .exr as a separate file.
#2. if the .exr does not have the Z-depth channel then it works
The .exr is a 32bit per channel RGBA + Z-depth channel.
The .exr shows normally in the viewport.
Open the .blend file and only change the path to the file to where you are saving the .exr.
Press F12, it should render a pink plane.
Thank you.
Maverick (maverick) set Type to Bug.
Maverick (maverick) created this task.
Maverick (maverick) raised the priority of this task from to Needs Triage by Developer.
Bet this is OIIO crappyness. Just one more reason to make imake I/O plug-in like in Cycles and always use ImBuf subsystem? :)
