Loop selection doesn't work on Linux Mint 16 xfce
Linux Mint xfce 16 64
Broken: (2.7a)
Worked: N/A
Pressing alt+selection doesn't select the loop, tried with quick search and it works...ring selection works normally.
try to select with the short cut alt+Selection on vertex mode.
Angel Pat (valcar3d) raised the priority of this task from to Needs Triage by Developer.
Angel Pat (valcar3d) updated the task description. (Show Details)
Angel Pat (valcar3d) set Type to Bug.
Not sure if this is considered a bug.
I have Linux Mint 15, and IIRC, several shortcuts using alt key don't work due to conflicts. Normally Blender comes with two shortcuts for this loop selection : alt-Select and alt-shift-Select (for Linux). Try if the later works for you.
Oh yeah you are right kevin, works with alt-shift-select, too bad is not an out of the box experience...
Okay then, closing this one !
