Tangents/bitangents missing from exported FBX model #39792
Reference: blender/blender#39792
Windows 7 64bit
2.70
4ed16bc
When exporting a static model as FBX, tangents and bitangents are missing in the .fbx file.
Default new file.
Select the cube and add a material.
Under the Material's Shading section, check Tangent Shading. (Unnecessary to reproduce bug, but I thought it might be required.)
Add a new image file texture to the material. Create a new one and assign Color Grid to make it visible.
Set texture's mapping coordinates to UV and check it's Influence box for Normal under Geometry.
Go to UV Editing interface and perform cube projection on all vertices.
Go to File->Export->Autodesk FBX
Check Selected Objects and Tangent Space. Save the fbx file.
Observe, using FBX SDK that there are no tangents or bitangents in the fbx file when it is imported. This happens with the binary. With the ASCII export, I can read the file and see no tangents or bitangents.
fbx_tangents.blend
Added subscriber: @cypherdare
To clarify, I know tangents may not be in a mesh imported to Blender from FBX. I mean that when I use a third party program (in my case, libgdx/fbx-conv) that relies on the FBX SDK to import and translate the mesh, the mesh does not have tangent or bitangent attributes for the vertices.
Legacy ASCII 6.1 exporter does not support tangents, this is expected.
I just fixed a typo in bin 7.4 exporter, but it does not seems to be enough for Unity (though data are in FBX mesh, likely yet another tiny details that breaks it). Could you please attach a valid FBX file having working tangents/binormals (the simpler the better)? It should be saved with a recent version of Maya/Max/... (i.e. be in the 7.x family of FBX formats).
I don't use anything besides Blender, but I can try downloading a trial of one of the Autodesk programs tomorrow night and making one.
I haven't used Unity in a while, but I seem to remember Unity generating its own tangents when importing a model, if you have set a normal map on the model correctly. So I'm not sure if it just ignores FBX tangents and generates its own. And maybe it is not showing tangents because you don't have the materials set up just so in Unity. Maybe I can experiment with that this weekend.
I'm personally interested in using this with LibGDX, which uses the LibGDX fbx-conv program to convert FBX files into their own G3D format. I looked over the source of fbx-conv, and it seems to rely completely on the FBX SDK to acquire the mesh. So as far as I can tell from the source, tangents will definitely be in the exported G3D file if they were in the original FBX file, provided the FBX SDK isn't buggy.
So this might be a good way to test the validity of the FBX file's tangents. You can export G3D as a JSON file instead of binary so you can easily see if the tangents are there. The vertex attributes are listed right at the top of the JSON file.
Example:
fbx-conv -o G3DJ input.fbx output.g3dj
Can you attach an FBX file that you've exported with your latest? I'd like to see how it does with fbx-conv if you don't have the time.
untitled_blend.fbx
Note Unity computes tangents by default, but has an option to import them instead (and with this files, this generates a warning saying there is no tangent nor binormal data). And since Unity uses FBXSDK like everyone else but Blender…
OK, same result in fbx-conv, no tangent or bitangent attributes, which follows what you said since they both use the FBX SDK. I'll try to get you that Maya-exported file tonight.
I didn't have enough time to check this file over after exporting. Took me a while to figure out how to make it since I haven't used Maya since the Maya PLE days about 10 years ago.
It may not have normals and bitangents and bitangents. If not, I'll try to redo it tonight.
simple_block.fbx
This issue was referenced by blender/blender-addons@7aebdfb396
Closed by commit blender/blender-addons@7aebdfb396.
@cypherdare Thanks for the file (ultimately, was yet another stupid tiny detail missing in generated FBX :/ ). Could you please test one of our next nightly builds tomorrow to check it actually works as expected? All I can say is that Unity now seems to load them OK (no warning nor error message)…
It's working in LibGDX via fbx-conv. Thank you for working through this! It's going to be well appreciated by many indie game developers, I think.
Cool, and thanks for the feedback! :)
