Cycles Motion Blur is broken #39840
Reference: blender/blender#39840
win64 i7 gtx titan
blender-2.70-b179647-win64
Multiple issues here both with Cycles and Internal. Cycles is more severe though.
Cycles:
1.Mblur fails for simple scaling
2.Mblur looks washed for last frame of the animation.
For example if you render the frame #6 you won't see any mblur even for a shutter time of 4.0
Blender Internal
1.Sampled motion blur fails for the last frame. Internal seems to sample only after the active frame instead of before and after.
Check attached files.
Thank you
mblur_bug.blend
Added subscriber: @dragostanasie
Added subscriber: @joel.godin
I think it is still not enabled.
"Currently scale motion is not supported, only object transformations like translation and rotation. "
http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Integrator
Cycles does not currently support scale motion as mentioned here:
http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Integrator#Motion_Blur
Further object motion only supports taking three samples, one at a earlier frame, current frame and later frame. For fast motion and/or long shutter time this indeed not great, but it's again a documented limitation, the steps option is only for deformation motion blur.
http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.71/Cycles
Blender Internal for some reason has always taken the shutter time after the current frame, rather than centering it around the current frame. That's easily changed with a patch like this, but it would break backwards compatibility to change this so I won't.
Thanks for clearing this up brecht.
Will motion blur be improved to allow fast motion by sampling fractional frames or more frame ahead and before ?
This is needed for things like insect wings, hands, fingers, and other character interactions with objects.
About the internal, maybe sampling before and ahead could be added as an option without the need to break backwards compatibility if it's not too much trouble.
Thank you.
The Cycles issue will be solved at some point, not sure yet when.
For Blender Internal, I've added it to the To Do list. There's no maintainer for that anymore so not sure if/when that will be fixed.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Render
