Linking path problem #39949
7 Participants
Reference: blender/blender#39949
OS: windows7 64bit
GPU: nvidia quadro k4000
Broken: 2.70a offical release
Worked: 2.69 official release
some weired stuff happening with the linked path
i don't know exactly in which situation this happens but sometimes the linking messes up the path and it assumes that the blend file is in c:\ instead of the correct path.
heres the error i get with 2.7+
all i do is link a object from one scene into a other and then try to reload the scene.
if you need more information please let me know so i can allocate some time to for reproducing this problem.
Added subscriber: @DanielGrauer
Added subscriber: @Sergey
Ofcourse we do need more information, in particular exact steps reproducing the issue, or at least .blend files which worked in 2.69 and doesn't work in 2.70.
No answer since one week…
finally got time to take the scenes apart so i can submit them here. you will find 2 blend files in the packed file with the same folder structure that i use.
so how to reproduce this issue:
if you manually saved the wire.blend file then either manually reload it or use the "revert"(which should be renamed to reload) option in the file menu to reload the wire.blend file and notice that the skin is not linked anymore and you will find some similar output like i posted in the first post.
linking.zip
Added subscriber: @mont29
The path in Wire.blend is simply broken. it reads library "............\Leg.blend" which is totally outside from your project folder. It should be "........\Leg.blend". Saving files with broken links would lead to data loss for sure.
i dont know how blender refers to such a path, thats why im creating this report.
my savings are exactly in the same file structure as in the files i attached.
if you make such a claim, maybe you can explain to me how i would save a file with a so called "broken" path. because i dont know how to save a file with a path i can not define and doesnt even exist...
"//" means the path is measured relative to the current .blend file. ".." means going to the parent directory. Relative path might become incorrect when you move files around in a file browser or so.
If you didn't change location of the .blend files and run into an issue with wrong paths, that'd be an issue and we'll need to know how to reproduce such situation from scratch.
im pretty sure i did not move any files around because im fully aware that this messes up the relative paths. i will have a look today if maybe a coworker did something which could cause such an issue but i was the only one working on these projects so its unlikely...
i replaced a drive recently but the drive letter and the location of the files is the same again so i dont see how this would break the relative paths.
Well, the thing is. Something breaks relative path for you and we can'r really guess what exactly. We need your collaboration here :)
If we know which step exactly breaks the relative path then we can totally fix the issue.
i understand and i will see if i can allocate some more time or give time to my intern to try and reproduce this somehow.
Added subscriber: @kaspwe2
i did some further testing and the problem happens when i link an object in with a relative path. with absolute path it works fine but as soon as the path is relative i get these funky paths.
i also tested in a old version 2.60.0 and there it works without any problems. i will do some more testing to narrow down the search for the issue.
i also found a old report that sound very similar to my problem, i believe the fix that was done there did not really fix the issue.
old report about same issue:
https://developer.blender.org/T37240
It might be related, maybe not. Really difficult to tell for sure without having exact steps reoproducing the issue.
Also, just for the record, all open movies production files always uses relative path. And the fact that we didn't have issues with paths there means that we REALLY need exact steps which moves linked files from consistent state to a broken one.
we are working on it but its hard to tell what is reproducable on your machines when the issue can be reproduced every time on the file we provide but you tell us you can not reproduce it....
i wrote the exact steps with the attached file structure and i can reproduce it every time so i dont know why this would not happen on any other (windows) system.
Added subscriber: @JasonvanGumster
It seems this issue rises as a result of having .blend files that link to assets in one another. That is, A.blend has an object, "1" that is linked from B.blend. And B.blend has an object, "2" that is linked from A.blend. It's kind of a circular linking scenario.
Assuming that is the culprit, a few follow-up questions (mostly related to the Edit Linked Library addon you're using):
The bug occurs in all three cases under the following circumstances:
Switching blend files with the "Edit linked library" addon.
How to reproduce:
Blender version. 2.70a Hash:
f93bc76
You can do it within the same blender instance. Happens with linked, dupligroup and proxies.
Added subscriber: @lukaszfito
Added subscriber: @Sparazza
Same problem in 2.78a using "Edit Linked Libraries" addon
The problem to me occurs only into Windows OS, not in linux because of the different slash-backslash I think
If you have some issues please submit them as a new report with proper steps reproducing the error.
I saw now that this is closed... really sorry about that, I will open a new one
