Wrong menu display
Broken: master - rB3448822b2ffc2a560c6902470d5a572dfa344e1d
In the VSE when you use the search menu and find Select By Type, the menu that appears displays selection options from the 3dview.
There is an addon that adds Select By Type to The VSE Select menu but this menu is available with or without the addon enabled.
Shane Ambler (sambler) set Type to Bug.
Shane Ambler (sambler) created this task.
Shane Ambler (sambler) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) closed this task as Archived.Apr 29 2014, 4:41 PM
Well, in the end, there is no bug here… We want to keep the 'select object' ops available from everywhere, and this does not prevent from using the one from the op (you should simply have to entries with same name).
