Continued incorrect single arm editing of aligned handles in graph editor #39982
Reference: blender/blender#39982
Windows 7 Pro 64-bit
Intel Core i7-4770K CPU @3.50GHz
ASUS nVidia GeForce GTX 760 2GB GDDR5 DirectCU Mini
Broken: Blender 2.70
4849ca8
There is still incorrect behavior evident when attempting to edit a single curve control handle in the graph editor.
This incorrect behavior was reported in bug report #38594 and then in bug report #39947. In fact, it appears that the updates have introduced new problems in the editing behaviour.
PLEASE NOTE: I am listing these all together in one report because I believe that all of the incorrect behaviour mentioned below relates to the same bit of code and needs to be fixed all at the same time rather than bit by bit. If I am incorrect in this, let me know and I will happily break this down into separate bug reports.
The following problems are noted:
With the MOVE command 'G':
In point of fact, this problem now makes it effectively impossible to edit the aligned control arms around an anchor point. If you move one arm, the other arm changes length. If you then select the other arm and attempt to move it back to the original length then the arm previously edited will now also change position.
NOTE: The use has to be able to move a single control arm of an aligned pair. When this happens the control arm on the opposite side will have to rotate to maintain alignment with the selected and edited arm. However, the unslected control arm should never – I repeat, NEVER – change length during this editing operation.
With the SCALE command 'S':
The user needs to be able to scale a single control arm in order to control the tension of the curve.
This was working correctly before the changes to this bit of code.
Additional editing problem with the SCALE command:
This seems to have something to do with the X value of the arm length suddenly flipping over to a negative value. This is undesirable behaviour. The scaling values of the arm length should never be allowed to go negative during this operation.
[ Note: For the record, I have observed that the scaling values provided by the mouse cursor seem to be somewhat erratic and that input seems to vary depending upon just where the mouse cursor is in the editing window when the 'S' key is pressed to initiate the command, but that is something for another bug report. ]
With the ROTATE command 'R':
During the time that the control arm scales, the opposite control arm is also being allowed to scale in length. This is undesirable (see description of this problem above as related to the MOVE command)
This scale operation should not occur during a ROTATE command. If a control arm is rotated to the extreme vertical position (either positive or negative) then it should simply stop there and not be allowed to further nor to suddenly become shorter or flip over to negative.
Added subscriber: @ignatz
Added subscribers: @ideasman42, @JoshuaLeung, @mont29
Added subscriber: @Sergey
@JoshuaLeung, while you're on looking into other issues with curves, mind looking into this one as well?
@JoshuaLeung - Just wanted to add an extra observation about the ROTATE command.
[ Note: This observation applies to the code from Blender 2.69 but has bearing on the current situation ]
When only the anchor point is select (instead on a single control arm) then the rotatation occurs without scaling either of the arms attached to that anchor point.
On the other hand, if only a single anchor point is selected and then the rotate command is invoked, the arm on the opposite side of the anchor point is subject to wild overshoot.
This would seem to suggest that one should invoke that same anchor point ROTATE algorithm in those cases when only a single control arm is selected.
bc9e66f083
reverted the change that broke scaling a single handle.rotating is still a bit strange, but for now this is a known-limitation.
thanks for such a comprehensive report, but at this point the logic is changed so it matches 2.68 and previous.
closing.
