Blender quits on undo/redo after changing object color #40046
Reference: blender/blender#40046
Win7/64, AMD HD6850
blender-2.70-c6d8540-win64: works
blender-2.70-9de24c8-win64: broken
2.70a official: works
blender-2.70-6e9c2d0-win64: broken
blender-2.70-362b25b3-win64: broken
Undo (Ctrl+Z). => Blender quits without a message. I've made several tests, and normally it quits immediatelly, but sometimes you have to press Undo,Redo,Undo,Redo,... several times to make it quit.
Please note which versions mentioned above crash/work: Broken with nightly, then works with official, then broken again.
Crash log: UndoRedo.crash.txt
Added subscriber: @willi-2
Added subscriber: @mont29
Cannot confirm that on Linux64 with recent builds, neither release nor debug+asan, neither with your file nor with default cube…
Assuming this is a windows issue for now? Can someone on this platform try to reproduce?
Added subscribers: @MartijnBerger, @ThomasDinges
This is strange. Did some more tests:
In VM:
362b25b3
,7660218
(x64),7660218
(x86, VC12)On physical machine:
7660218-win64: still crash
7660218-win32-vc12: works!
Narrowing down with 7660218-win64:
This is hard to catch because undo/redo has to be done several times until it crashes, so I never know when it's safe to say it "works". In addition, after restarting Blender, the same situation sometimes works and sometimes crashes.
Still investigating...
The "safest" situation should be:
Load UndoRedo.blend without UI
If I do this, it still crashes.
Though, it always works with
c6d8540
, and also with latest 32 bit build. "Always" means: Starting Blender four times, and each time doing undo/redo about 50 times.:-/
Using Windbg, I can see that Undo causes an access violation. But without debug symbols, there's unfortunatelly nothing helpful I can provide now - can I?
....However: The 32 bit version that always works if started from Windows Explorer (double-click) also sometimes crashes if started via command line (current dir=blender dir).
Oh, sometimes the console says "error: not freed memory blocks: 180" (or other number) when quitting even though I performed the same steps as the previous time where it did not report any not freed memory blocks.
Sorry, this is too random to give more reliable information.
I have a fix for this prepared. will commit soon (or send for review)
Will commit workaround, but moving to TODO since a real fix is very involved.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Properties_Editor
Oh, ok. Thanks a lot for looking into it anyway.
@willi-2, to be clear, the crash is fixed, just not in such a nice way.
