python addobject #40097
7 Participants
Reference: blender/blender#40097
windows 7 nvidida 560 ti
2.70 a
function: scene.addObject (object, other, time = 0) does not create object
and produces no error console
code:
from bge import logic as gl
rainObj = gl.getCurrentController().owner
new = gl.getCurrentScene().addObject("rain",rainObj,70)
new.position = [0.0, 0.1, 0.6]
Added subscriber: @moaaa_user
Added subscriber: @Moguri
I cannot reproduce the bug (KX_Scene.addObject() appears to be working fine). Please supply a blendfile demonstrating the problem. I've attached the file I'm using, which works correctly for me.
addobject_test.blend
I'll put the piece of code that I have always used
Added subscriber: @solarlune
Maybe you could provide a blend file of your own that provides the problem, as the code itself doesn't do much.
the code is in exemple blend file look my last comment
Ah, I see. Thank you.
However, this isn't a bug at all - it's just a user error.
The rain object in your example was set to Billboard, and you had the front of the plane facing -X, The front face should face +X. Since the material had backface culling enabled and Billboard was on, Blender was turning the back (invisible) face to the camera (which it should have been doing).
Solution: Rotate the rain object plane 180 degrees in edit mode, or disable back-face culling in the material options.
Something that could have helped you see what was going on:
You could enable static physics on the rain objects and turn on physics visualization, or attach a Python controller and print out a statement to ensure they're being created.
Please ask for help on the BlenderArtists forums to ensure everything is working correctly on your end before reporting possible bugs to help save resources in the future.
sorry
as file work perfectly in the three latest version of blender.
I can not think of anything other than a bug
I believe the requirement for Billboard and Halo was changed between those versions from the face needing to face -X to +X intentionally. Anyway, no problem. I take it this bug can be closed?
What version was it first flipped in? 2.70? I'm not seeing anything in the release notes; it would be good if these kind of changes were documented.
@Moguri - I'm not sure. I think I recall it being a patch from vitorbalbio that was committed somewhat recently (in the past few months), but I'm only able to turn up a patch from October that was committed but then reverted. If it were committed finally in October, then that would be 2.69, I think.
Added subscriber: @JacobMerrill-1
Yeah, it was flipped in 2.7 (I had to flip normals on all halo objects in my game)
Added subscribers: @ideasman42, @brecht
Campbell, Brecht, do either of you know what happened here (why are our halos flipped now)?
Added subscriber: @mont29
Added subscriber: @JorgeBernalMartinez
Can I close this report?
after 5 releases, It doesn't seem a good idea flip halo normals breaking compatibility again. Then, I propose leave current behaviour as it is and to close the report.
Added subscriber: @panzergame
Edit mode -> ctrl + F -> flip normal
