replaceMesh() Crashes BGE When Used on a Parented Object
Windows 7 64-bit, AMD Radeon 7700
Broken: Blender 2.7 362b25b3 5/4/14
If you use replaceMesh() on an object that is parented to another object, the game engine crashes when closing.
It looks like it might be an issue regarding object references. If replaceMesh is called once, then the child object's mesh is replaced correctly. If it's called several times (over several children, for example), then the parent gets destroyed entirely...?
I'm also having an issue in which running replaceMesh on several different children crashes the engine when starting the engine, and not just when stopping, but I haven't replicated it in the example. I'm assuming it's the same issue.
I would guess this crash might be related to this issue which should be fixed, though it's just a guess because of the similar problems: https://developer.blender.org/T38170
The .crash.txt file doesn't contain any useful information other than the Blender version.
Just press P to start the engine and see the planes' meshes be replaced with pyramids (correct), and then have Blender crash on closing (incorrect, haha).
solarlune created this task.May 9 2014, 5:17 PM
solarlune raised the priority of this task from to 90.
solarlune updated the task description. (Show Details)
solarlune added a project: Game Engine.
solarlune edited a custom field.
solarlune added a subscriber: solarlune.
As usual, feel free to reassign/dispatch those bugs.
Mitchell Stokes (moguri) lowered the priority of this task from 90 to 50.
Is this a recent issue, or did older versions of Blender also have this issue?
Sorry about that - this is a recent issue. Blender 2.70a was fine.
Mitchell Stokes (moguri) changed the task status from Unknown Status to Resolved.May 13 2014, 7:55 AM
Closed by commit rB43f3e79ceeb9.
