Problem in normal with subdivision surface + Boolean modifier
Win x64, Geforce GTX 560TI
rev. 31849ca
MSVC2013 + Cmake
When using a object that have a subdivision surface modifier as boolean mask to other object the normals are always flat in the generate faces by the boolean operator it ignore the normal of the model. This problem not occur in blender 2.70a
  1. Open the uploded file
  2. Select the sphere object ( it's visibility was set to bound to see better the effect )
  3. Try to change the shade to smooth or flat, it don't work (in Blender 2.70a it works)
  4. When you delete the subdivision modifier it works.
Vitor Balbio (vitorbalbio) created this task.
Vitor Balbio (vitorbalbio) raised the priority of this task from to Needs Triage by Developer.
