"Right mouse" operates "View persp" when use "Screencast Keys"
Closed, InvalidPublic
Windows 7 64bit
Radeon HD6450
2.70a f93bc76
"Right mouse" operates "View persp" when use "Screencast Keys".
This feature should work only in "Num5".
1 "Screencast Keys" to enable
2 use "View ortho"
3 Anything of the 3D view right clicks the place that there isn't.
State becomes "View persp".
(Since I'm inverting the R/L mouse button, it might occur in the left click.)
meny thanks.
Aya Ayatani (Ayne) raised the priority of this task from to Needs Triage by Developer.
Aya Ayatani (Ayne) updated the task description. (Show Details)
Aya Ayatani (Ayne) added a project: Add-ons.
Aya Ayatani (Ayne) set Type to Bug.
I cant redo this bug, but sounds like auto-perspective preference?
Campbell Barton (campbellbarton) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.May 14 2014, 2:05 AM
What do you expect to happen when Right mouse is pressed?
Hi,
I have found that it does not occur in the key configuration of default.
I have used the following.
However, this does not have a setting to use the 'View persp 'by "rightmouse".
import bpy
import os
def kmi_props_setattr(kmi_props, attr, value):
try:
except AttributeError:
    print("Warning: property '%s' not found in keymap item '%s'" %
          (attr, kmi_props.__class__.__name__))
except Exception as e:
    print("Warning: %r" % e)
wm = bpy.context.window_manager
kc = wm.keyconfigs.new(os.path.splitext(os.path.basename(file))[0])
Map 3D View
km = kc.keymaps.new('3D View', space_type='VIEW_3D', region_type='WINDOW', modal=False)
kmi = km.keymap_items.new('view3d.screencast_keys', 'C', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('view3d.manipulator', 'LEFTMOUSE', 'PRESS')
kmi_props_setattr(kmi.properties, 'release_confirm', True)
kmi = km.keymap_items.new('view3d.cursor3d', 'LEFTMOUSE', 'CLICK', shift=True)
kmi = km.keymap_items.new('view3d.rotate', 'RIGHTMOUSE', 'PRESS')
kmi = km.keymap_items.new('view3d.move', 'MIDDLEMOUSE', 'PRESS')
kmi = km.keymap_items.new('view3d.zoom', 'MIDDLEMOUSE', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.dolly', 'MIDDLEMOUSE', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.view_selected', 'NUMPAD_PERIOD', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'use_all_regions', True)
kmi = km.keymap_items.new('view3d.view_selected', 'NUMPAD_PERIOD', 'PRESS')
kmi_props_setattr(kmi.properties, 'use_all_regions', False)
kmi = km.keymap_items.new('view3d.view_lock_to_active', 'NUMPAD_PERIOD', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.view_lock_clear', 'NUMPAD_PERIOD', 'PRESS', alt=True)
kmi = km.keymap_items.new('view3d.navigate', 'F', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.smoothview', 'TIMER1', 'ANY', any=True)
kmi = km.keymap_items.new('view3d.rotate', 'TRACKPADPAN', 'ANY')
kmi = km.keymap_items.new('view3d.rotate', 'MOUSEROTATE', 'ANY')
kmi = km.keymap_items.new('view3d.move', 'TRACKPADPAN', 'ANY', shift=True)
kmi = km.keymap_items.new('view3d.zoom', 'TRACKPADZOOM', 'ANY')
kmi = km.keymap_items.new('view3d.zoom', 'TRACKPADPAN', 'ANY', ctrl=True)
kmi = km.keymap_items.new('view3d.zoom', 'NUMPAD_PLUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'delta', 1)
kmi = km.keymap_items.new('view3d.zoom', 'NUMPAD_MINUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'delta', -1)
kmi = km.keymap_items.new('view3d.zoom', 'EQUAL', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.zoom', 'MINUS', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.zoom', 'WHEELINMOUSE', 'PRESS')
kmi = km.keymap_items.new('view3d.zoom', 'WHEELOUTMOUSE', 'PRESS')
kmi = km.keymap_items.new('view3d.dolly', 'NUMPAD_PLUS', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.dolly', 'NUMPAD_MINUS', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.dolly', 'EQUAL', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.dolly', 'MINUS', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.zoom_camera_1_to_1', 'NUMPAD_ENTER', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.view_center_camera', 'HOME', 'PRESS')
kmi = km.keymap_items.new('view3d.view_center_lock', 'HOME', 'PRESS')
kmi = km.keymap_items.new('view3d.view_center_cursor', 'HOME', 'PRESS', alt=True)
kmi = km.keymap_items.new('view3d.view_center_pick', 'F', 'PRESS', alt=True)
kmi = km.keymap_items.new('view3d.view_all', 'HOME', 'PRESS')
kmi_props_setattr(kmi.properties, 'center', False)
kmi = km.keymap_items.new('view3d.view_all', 'HOME', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.view_all', 'C', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'center', True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_0', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'CAMERA')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_1', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'FRONT')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F1', 'PRESS')
kmi = km.keymap_items.new('view3d.view_orbit', 'NUMPAD_2', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'ORBITDOWN')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_3', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'RIGHT')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F3', 'PRESS')
kmi = km.keymap_items.new('view3d.view_orbit', 'NUMPAD_4', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'ORBITLEFT')
kmi = km.keymap_items.new('view3d.view_persportho', 'NUMPAD_5', 'PRESS')
kmi = km.keymap_items.new('view3d.view_orbit', 'NUMPAD_6', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'ORBITRIGHT')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_7', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'TOP')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F2', 'PRESS')
kmi = km.keymap_items.new('view3d.view_orbit', 'NUMPAD_8', 'PRESS')
kmi_props_setattr(kmi.properties, 'type', 'ORBITUP')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_1', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'BACK')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F1', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_3', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'LEFT')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F3', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_7', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'BOTTOM')
kmi = km.keymap_items.new('view3d.viewnumpad', 'F2', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.view_pan', 'NUMPAD_2', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'PANDOWN')
kmi = km.keymap_items.new('view3d.view_pan', 'NUMPAD_4', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'PANLEFT')
kmi = km.keymap_items.new('view3d.view_pan', 'NUMPAD_6', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'PANRIGHT')
kmi = km.keymap_items.new('view3d.view_pan', 'NUMPAD_8', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'type', 'PANUP')
kmi = km.keymap_items.new('view3d.view_roll', 'NUMPAD_4', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'angle', -0.2617993950843811)
kmi = km.keymap_items.new('view3d.view_roll', 'NUMPAD_6', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'angle', 0.2617993950843811)
kmi = km.keymap_items.new('view3d.view_pan', 'WHEELUPMOUSE', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.view_pan', 'WHEELDOWNMOUSE', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.view_pan', 'WHEELUPMOUSE', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.view_pan', 'WHEELDOWNMOUSE', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.view_orbit', 'WHEELUPMOUSE', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.view_orbit', 'WHEELDOWNMOUSE', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.view_orbit', 'WHEELUPMOUSE', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('view3d.view_orbit', 'WHEELDOWNMOUSE', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('view3d.view_roll', 'WHEELUPMOUSE', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.view_roll', 'WHEELDOWNMOUSE', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_1', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'align_active', True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F1', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_3', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F3', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_7', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F2', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_1', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F1', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_3', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F3', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NUMPAD_7', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'F2', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.localview', 'NUMPAD_SLASH', 'PRESS')
kmi = km.keymap_items.new('view3d.ndof_orbit_zoom', 'NDOF_MOTION', 'ANY')
kmi = km.keymap_items.new('view3d.ndof_orbit', 'NDOF_MOTION', 'ANY', ctrl=True)
kmi = km.keymap_items.new('view3d.ndof_pan', 'NDOF_MOTION', 'ANY', shift=True)
kmi = km.keymap_items.new('view3d.ndof_all', 'NDOF_MOTION', 'ANY', shift=True, ctrl=True)
kmi = km.keymap_items.new('view3d.view_selected', 'NDOF_BUTTON_FIT', 'PRESS')
kmi = km.keymap_items.new('view3d.view_roll', 'NDOF_BUTTON_ROLL_CCW', 'PRESS')
kmi_props_setattr(kmi.properties, 'angle', -1.5707963705062866)
kmi = km.keymap_items.new('view3d.view_roll', 'NDOF_BUTTON_ROLL_CW', 'PRESS')
kmi_props_setattr(kmi.properties, 'angle', 1.5707963705062866)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_FRONT', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_BACK', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_LEFT', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_RIGHT', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_TOP', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_BOTTOM', 'PRESS')
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_FRONT', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_RIGHT', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.viewnumpad', 'NDOF_BUTTON_TOP', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.layers', 'ACCENT_GRAVE', 'PRESS')
kmi_props_setattr(kmi.properties, 'nr', 0)
kmi = km.keymap_items.new('view3d.layers', 'ONE', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 1)
kmi = km.keymap_items.new('view3d.layers', 'TWO', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 2)
kmi = km.keymap_items.new('view3d.layers', 'THREE', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 3)
kmi = km.keymap_items.new('view3d.layers', 'FOUR', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 4)
kmi = km.keymap_items.new('view3d.layers', 'FIVE', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 5)
kmi = km.keymap_items.new('view3d.layers', 'SIX', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 6)
kmi = km.keymap_items.new('view3d.layers', 'SEVEN', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 7)
kmi = km.keymap_items.new('view3d.layers', 'EIGHT', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 8)
kmi = km.keymap_items.new('view3d.layers', 'NINE', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 9)
kmi = km.keymap_items.new('view3d.layers', 'ZERO', 'PRESS', any=True)
kmi_props_setattr(kmi.properties, 'nr', 10)
kmi = km.keymap_items.new('wm.context_toggle_enum', 'Z', 'PRESS')
kmi_props_setattr(kmi.properties, 'data_path', 'space_data.viewport_shade')
kmi_props_setattr(kmi.properties, 'value_1', 'SOLID')
kmi_props_setattr(kmi.properties, 'value_2', 'WIREFRAME')
kmi = km.keymap_items.new('wm.context_toggle_enum', 'Z', 'PRESS', alt=True)
kmi_props_setattr(kmi.properties, 'value_2', 'TEXTURED')
kmi = km.keymap_items.new('wm.context_toggle_enum', 'Z', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value_2', 'RENDERED')
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS')
kmi_props_setattr(kmi.properties, 'extend', False)
kmi_props_setattr(kmi.properties, 'deselect', False)
kmi_props_setattr(kmi.properties, 'toggle', False)
kmi_props_setattr(kmi.properties, 'enumerate', False)
kmi_props_setattr(kmi.properties, 'object', False)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'toggle', True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'object', True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', alt=True)
kmi_props_setattr(kmi.properties, 'enumerate', True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', shift=True, ctrl=True)
kmi_props_setattr(kmi.properties, 'extend', True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('view3d.select', 'SELECTMOUSE', 'PRESS', shift=True, ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.select_border', 'B', 'PRESS')
kmi = km.keymap_items.new('view3d.select_lasso', 'EVT_TWEAK_A', 'ANY', ctrl=True)
kmi = km.keymap_items.new('view3d.select_lasso', 'EVT_TWEAK_A', 'ANY', shift=True, ctrl=True)
kmi_props_setattr(kmi.properties, 'deselect', True)
kmi = km.keymap_items.new('view3d.select_circle', 'C', 'PRESS')
kmi = km.keymap_items.new('view3d.clip_border', 'B', 'PRESS', alt=True)
kmi = km.keymap_items.new('view3d.zoom_border', 'B', 'PRESS', shift=True)
kmi = km.keymap_items.new('view3d.render_border', 'B', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'camera_only', True)
kmi = km.keymap_items.new('view3d.render_border', 'B', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'camera_only', False)
kmi = km.keymap_items.new('view3d.clear_render_border', 'B', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.camera_to_view', 'NUMPAD_0', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('view3d.object_as_camera', 'NUMPAD_0', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.call_menu', 'S', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'name', 'VIEW3D_MT_snap')
kmi = km.keymap_items.new('view3d.copybuffer', 'C', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('view3d.pastebuffer', 'V', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.context_set_enum', 'COMMA', 'PRESS')
kmi_props_setattr(kmi.properties, 'data_path', 'space_data.pivot_point')
kmi_props_setattr(kmi.properties, 'value', 'BOUNDING_BOX_CENTER')
kmi = km.keymap_items.new('wm.context_set_enum', 'COMMA', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'value', 'MEDIAN_POINT')
kmi = km.keymap_items.new('wm.context_toggle', 'COMMA', 'PRESS', alt=True)
kmi_props_setattr(kmi.properties, 'data_path', 'space_data.use_pivot_point_align')
kmi = km.keymap_items.new('wm.context_toggle', 'SPACE', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'data_path', 'space_data.show_manipulator')
kmi = km.keymap_items.new('wm.context_set_enum', 'PERIOD', 'PRESS')
kmi_props_setattr(kmi.properties, 'value', 'CURSOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'PERIOD', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'value', 'INDIVIDUAL_ORIGINS')
kmi = km.keymap_items.new('wm.context_set_enum', 'PERIOD', 'PRESS', alt=True)
kmi_props_setattr(kmi.properties, 'value', 'ACTIVE_ELEMENT')
kmi = km.keymap_items.new('transform.translate', 'G', 'PRESS')
kmi = km.keymap_items.new('transform.translate', 'EVT_TWEAK_S', 'ANY')
kmi = km.keymap_items.new('transform.rotate', 'R', 'PRESS')
kmi = km.keymap_items.new('transform.resize', 'S', 'PRESS')
kmi = km.keymap_items.new('transform.bend', 'W', 'PRESS', shift=True)
kmi = km.keymap_items.new('transform.tosphere', 'S', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('transform.shear', 'S', 'PRESS', shift=True, ctrl=True, alt=True)
kmi = km.keymap_items.new('transform.select_orientation', 'SPACE', 'PRESS', alt=True)
kmi = km.keymap_items.new('transform.create_orientation', 'SPACE', 'PRESS', ctrl=True, alt=True)
kmi_props_setattr(kmi.properties, 'use', True)
kmi = km.keymap_items.new('transform.mirror', 'M', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.context_toggle', 'TAB', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'data_path', 'tool_settings.use_snap')
kmi = km.keymap_items.new('wm.context_menu_enum', 'TAB', 'PRESS', shift=True, ctrl=True)
kmi_props_setattr(kmi.properties, 'data_path', 'tool_settings.snap_element')
kmi = km.keymap_items.new('transform.translate', 'T', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'texture_space', True)
kmi = km.keymap_items.new('transform.resize', 'T', 'PRESS', shift=True, alt=True)
kmi = km.keymap_items.new('transform.skin_resize', 'A', 'PRESS', ctrl=True)
Map File Browser Main
km = kc.keymaps.new('File Browser Main', space_type='FILE_BROWSER', region_type='WINDOW', modal=False)
kmi = km.keymap_items.new('file.execute', 'LEFTMOUSE', 'DOUBLE_CLICK')
kmi_props_setattr(kmi.properties, 'need_active', True)
kmi = km.keymap_items.new('file.select', 'LEFTMOUSE', 'CLICK')
kmi = km.keymap_items.new('file.select', 'LEFTMOUSE', 'CLICK', shift=True)
kmi = km.keymap_items.new('file.select', 'LEFTMOUSE', 'CLICK', alt=True)
kmi_props_setattr(kmi.properties, 'fill', True)
kmi = km.keymap_items.new('file.select', 'RIGHTMOUSE', 'CLICK')
kmi_props_setattr(kmi.properties, 'open', False)
kmi = km.keymap_items.new('file.select', 'RIGHTMOUSE', 'CLICK', shift=True)
kmi = km.keymap_items.new('file.select', 'RIGHTMOUSE', 'CLICK', alt=True)
kmi.active = False
kmi = km.keymap_items.new('file.previous', 'BUTTON4MOUSE', 'CLICK')
kmi = km.keymap_items.new('file.next', 'BUTTON5MOUSE', 'CLICK')
kmi = km.keymap_items.new('file.select_all_toggle', 'A', 'PRESS')
kmi = km.keymap_items.new('file.refresh', 'NUMPAD_PERIOD', 'PRESS')
kmi = km.keymap_items.new('file.select_border', 'B', 'PRESS')
kmi = km.keymap_items.new('file.select_border', 'EVT_TWEAK_L', 'ANY')
kmi = km.keymap_items.new('file.rename', 'LEFTMOUSE', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('file.highlight', 'MOUSEMOVE', 'ANY', any=True)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_PLUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'increment', 1)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_PLUS', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'increment', 10)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_PLUS', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'increment', 100)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_MINUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'increment', -1)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_MINUS', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'increment', -10)
kmi = km.keymap_items.new('file.filenum', 'NUMPAD_MINUS', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'increment', -100)
Map Window
km = kc.keymaps.new('Window', space_type='EMPTY', region_type='WINDOW', modal=False)
kmi = km.keymap_items.new('object.translatedui_toggle', 'PAUSE', 'PRESS')
kmi = km.keymap_items.new('wm.window_duplicate', 'W', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('wm.read_homefile', 'N', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.save_homefile', 'U', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.call_menu', 'O', 'PRESS', shift=True, ctrl=True)
kmi_props_setattr(kmi.properties, 'name', 'INFO_MT_file_open_recent')
kmi = km.keymap_items.new('wm.link_append', 'O', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('wm.link_append', 'F1', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'link', False)
kmi_props_setattr(kmi.properties, 'instance_groups', False)
kmi = km.keymap_items.new('wm.save_mainfile', 'S', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.save_mainfile', 'W', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.save_as_mainfile', 'S', 'PRESS', ctrl=True, alt=True)
kmi_props_setattr(kmi.properties, 'copy', True)
kmi = km.keymap_items.new('wm.window_fullscreen_toggle', 'F11', 'PRESS', alt=True)
kmi = km.keymap_items.new('wm.quit_blender', 'Q', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('wm.redraw_timer', 'T', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('wm.debug_menu', 'D', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('wm.search_menu', 'SPACE', 'PRESS')
kmi = km.keymap_items.new('wm.call_menu', 'NDOF_BUTTON_MENU', 'PRESS')
kmi_props_setattr(kmi.properties, 'name', 'USERPREF_MT_ndof_settings')
kmi = km.keymap_items.new('wm.context_set_enum', 'F2', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'data_path', 'area.type')
kmi_props_setattr(kmi.properties, 'value', 'LOGIC_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F3', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'NODE_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F4', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'CONSOLE')
kmi = km.keymap_items.new('wm.context_set_enum', 'F5', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'VIEW_3D')
kmi = km.keymap_items.new('wm.context_set_enum', 'F6', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'GRAPH_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F7', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'PROPERTIES')
kmi = km.keymap_items.new('wm.context_set_enum', 'F8', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'SEQUENCE_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F9', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'OUTLINER')
kmi = km.keymap_items.new('wm.context_set_enum', 'F10', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'IMAGE_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F11', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'TEXT_EDITOR')
kmi = km.keymap_items.new('wm.context_set_enum', 'F12', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 'DOPESHEET_EDITOR')
kmi = km.keymap_items.new('wm.context_scale_float', 'NDOF_BUTTON_PLUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'data_path', 'user_preferences.inputs.ndof_sensitivity')
kmi_props_setattr(kmi.properties, 'value', 1.100000023841858)
kmi = km.keymap_items.new('wm.context_scale_float', 'NDOF_BUTTON_MINUS', 'PRESS')
kmi_props_setattr(kmi.properties, 'value', 0.9090908765792847)
kmi = km.keymap_items.new('wm.context_scale_float', 'NDOF_BUTTON_PLUS', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 1.5)
kmi = km.keymap_items.new('wm.context_scale_float', 'NDOF_BUTTON_MINUS', 'PRESS', shift=True)
kmi_props_setattr(kmi.properties, 'value', 0.6666666865348816)
kmi = km.keymap_items.new('info.reports_display_update', 'TIMER_REPORT', 'ANY', any=True)
Map Screen
km = kc.keymaps.new('Screen', space_type='EMPTY', region_type='WINDOW', modal=False)
kmi = km.keymap_items.new('screen.animation_step', 'TIMER0', 'ANY', any=True)
kmi = km.keymap_items.new('screen.region_blend', 'TIMERREGION', 'ANY', any=True)
kmi = km.keymap_items.new('screen.screen_set', 'RIGHT_ARROW', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.screen_set', 'LEFT_ARROW', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.screen_full_area', 'UP_ARROW', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.screen_full_area', 'DOWN_ARROW', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.screen_full_area', 'SPACE', 'PRESS', shift=True)
kmi = km.keymap_items.new('screen.screenshot', 'F3', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.screencast', 'F3', 'PRESS', alt=True)
kmi = km.keymap_items.new('screen.region_quadview', 'Q', 'PRESS', ctrl=True, alt=True)
kmi = km.keymap_items.new('screen.repeat_history', 'F3', 'PRESS')
kmi = km.keymap_items.new('screen.repeat_last', 'R', 'PRESS', shift=True)
kmi = km.keymap_items.new('screen.region_flip', 'F5', 'PRESS')
kmi = km.keymap_items.new('screen.redo_last', 'F6', 'PRESS')
kmi = km.keymap_items.new('script.reload', 'F8', 'PRESS')
kmi = km.keymap_items.new('file.execute', 'RET', 'PRESS')
kmi = km.keymap_items.new('file.execute', 'NUMPAD_ENTER', 'PRESS')
kmi = km.keymap_items.new('file.cancel', 'ESC', 'PRESS')
kmi = km.keymap_items.new('ed.undo', 'Z', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('ed.redo', 'Y', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('ed.undo_history', 'Z', 'PRESS', shift=True, ctrl=True)
kmi = km.keymap_items.new('render.render', 'F12', 'PRESS')
kmi_props_setattr(kmi.properties, 'use_viewport', True)
kmi = km.keymap_items.new('render.render', 'F12', 'PRESS', ctrl=True)
kmi_props_setattr(kmi.properties, 'animation', True)
kmi = km.keymap_items.new('render.view_cancel', 'ESC', 'PRESS')
kmi = km.keymap_items.new('render.view_show', 'F11', 'PRESS')
kmi = km.keymap_items.new('render.play_rendered_anim', 'F11', 'PRESS', ctrl=True)
kmi = km.keymap_items.new('screen.userpref_show', 'U', 'PRESS', ctrl=True, alt=True)
I don't want any action.
But it is identical to 'Num5' under the conditions mentioned above.
(View oltho to Persp only.)
meny thanks.
You have kmi = km.keymap_items.new('view3d.rotate', 'RIGHTMOUSE', 'PRESS') so, you need to disable auto-perspective preference (in interface section).
Hi
Yes.I have intentionally set it.
This event will occur if the right"drag" rather than a right-click.
However event occurs only right click the "Screencast Keys" runtime.
Thanks.
