Rigid Body Constraint: hinge ok, point not #40183
2 Participants
Reference: blender/blender#40183
Linux Ubuntu 14.x 64bit;
Windows 8.1 64bit;
Broken: blender 2.70a ... blender-2.70-51fa66b-win64
Worked: unknown
i created a "pendulum" for testing.
when i use the hinge rigid body constraint, the "pendulum" follow an expected circular path.
but when i use a point constraint, the "pendulum" leaves the expected circular path an seems to collides with something not existing.
the green cube follows the circular path (with the hinge constraint)
the red cube leaves the circular path and touches a invisible border and "loose much movement enegy"
bouncing, friction, damping is set to zero, so the pendulum should not getting slower, should not leave the ideal circular path and ther are no obstacle where the cube could collide with.
point_vs_hinge.blend
Added subscriber: @beta-tester
Added subscriber: @LukasTonne
Can confirm this looks bad.
Increasing the
Steps Per Second
in rigid body world settings helps a bit, but still shows quite blatant error.Same result happens with "Generic" (6dof) constraints on (0,0,0) translation limits btw. IMO these constraints should be much more stable in simple cases like this, so looks like a genuine bug to me.
So, apparently the distance between the two bodies is the crucial factor here. When you move them closer together it becomes very stable, moving them further apart causes ridiculous inaccuracies that build up over time. The "collision" you observed is probably some sanity limit based on a bounding box or so.
I'm closing this, because i think this is not a bug. Constraints are dynamic features and they can be quite susceptible to large/small values (distance, mass etc.).
The only viable generic solution is to really crank up the iterations (steps per second), unless you can build the scene in a more appropriate scale (ration of gravity to distance is what matter most here).
