bevel_factor_mapping_start/end in python loop #40223
Reference: blender/blender#40223
OSX 10.9, Macbook Pro Retina
Broken: 2.70.5
3889483
When I try to set the bevel_factor_mapping_values from python, Blender crashes.
Open the attached .blend file run the code (should be there already)ZHTraffic.blend:
Added subscriber: @cnd
crash is caused by
segcount = (int)(bl->nr / cu->resolu)
when bl->nr isnt dividing evenly29 / 12
- in this case.Also noticed
calc_bevfac_mapping
assumes cu->resolu, but resolu_ren could be used.use_render_resolution
arg should be passed by caller.I think I could fix it: bevfac_for_poly_splines.diff
Added subscriber: @mont29
This issue was referenced by
1923a8f23a
Closed by commit
1923a8f23a
.Changed status from 'Resolved' to: 'Open'
Re-opening: curve_crash.blend
vector bezier handles make the segment count incorrect (since they only use one segment).
inspired by "curve_to_displist()" I could fix the vector bezier handles issue.
Additionally I fixed a problem that became only visible with poly splines: swapping start and end factors occurred sometimes in the wrong place because last- and firstblend were not checked in the if-statement on line 1522. bevfac_for_poly_splines_2.diff
@cnd, the patch isnt applying on a recent build, would you mind updating the diff?
updating the diff bevfac_for_poly_splines_3.diff
Checked this patch and there are more issues, I'm testing with valgrind to report problems, while they don't cause crashes they are definitely bugs still.
First, the patch reverts a correction I made previously, when updating patches please check what changed, the reason the patch failed to apply was because a fix was made (check for zero
cu->resolu_ren
).There is a mismatch between
segcount
used to allocbevp_array
, and the index used to readcalc_bevfac_spline_mapping
(reads past array bounds).Cyclic curves also look to cause memory read errors with
bevp_array
, Im not sure this option even makes much sense for cyclic curves?, probably this should just be disabled?While testing I keep getting errors with
rotateBevelPiece
, its reading past array bounds (checks for first/last ignore that bevp is offset bystart
)I'm thinking maybe we should disable this for release, the more I check this feature the more bug's I keep finding.
Added subscriber: @ideasman42
Re-assigning
Note, we might be better off to store some info about the spline in
BevPoint
, having to calculate this after the fact is error prone.Though Im not completely sure of this either, would have to try it and see if it introduces other problems.
Sorry for urging you to test so much. I am new to C but I will get into the XCode Instruments to deliver a better performance in memory testing next time!
zero check for cu->resolu_ren is not necessary anymore since I get the segcount from nu. It also caused the spline to vanish completely. That might has to do with the array errors you discovered.
Cyclic splines: While I had the idea for this feature thinking about open curves, I think it makes sense for cyclic curves too. It basically always makes sense when you want to animate bevstart/end linearly but having segments not equal in length.
Ok. well I found mostly whats needed to fix this and we do a testbuild tomorrow, so Ill finish continue to finish off the fix.
91a91b9362
Closed by commit
91a91b9362
