Compound Physics - Origin does not shift. #40340
Reference: blender/blender#40340
Compound_center_of_gravity_bug.blend
CompoundParentingPhysicsBug.blend
Any
2.7a
Origin does not shift on compound parent, and if a compound physics bounded item is parented to another compound, it leaves an invisible copy of the physics item of the child.
press play
in example two the instructions are included in a text.
Added subscriber: @JacobMerrill-1
Added subscriber: @raco
In example two probably also another issue presents itself. In the Physics Properties both Cubes have 'Compound' checked. One is parented to the other, with 'Compound' checked in the Parent Actuator. This causes only the visible mesh to be updated. This is a different issue than the center of gravity bug. Just for your information.
Compound Physics - Origin does not shift, and if a compound physics bounded item is parented to another compound, it leaves an invisible copy of the physics item of the child.to Compound Physics - Origin does not shift.Added subscriber: @Moguri
In Bullet, the shape's transform matrix is it's "center." When adding objects to a compound shape, we don't adjust the parent's transform matrix. We could probably do this, but it requires digging through our physics code and possibly breaking games. A work around is to just create a small, invisible cube that you want to be your "center of gravity" and make it the root of the compound object. Any further objects added to the compound shape will be added relative to the root.
Added subscriber: @brita
Closing this as "Won't Fix". The supplied work-around I think is acceptable, and trying to "fix" this bug could just result in more physics bugs (and possibly breaking existing games).
What about adding a command
joinCompoundObjects([list objects]) that does the for-mentioned
Get center of mass
Get Mass
Add compound object "Root"
Parent top of Hierarchy chain to root?
(or something smarter)
using a python function or class?
I agree it would get too messy, but I don't think this work-around is perfect enough, let alone fitted to add as a function to the API. I don't think you can't even call it a work-around, because the result is far from perfect. There's still the collision mesh of the added 'parent' object to consider. Even if this would be cube as small as a grain, its vertexes would still interfere with collision. Here's a blend to illustrate this: Compound_centroid_work-around_flaw.blend
A solution for this maybe would be to add compatibility with Material Physics for Compound objects. Currently if the Compound parent would have a material with Physics disabled, this would cause all added geometry to have no Physics enabled as well. So if Compound parenting would also take into consideration the Materials of the children, then we could have a complete work-around.
