Viewport has 8fps if i open Animation viewports. #40372
Closed
opened 2014-05-26 22:13:48 +02:00 by paul geraskin · 15 comments
Member
Linux 64,
2.70.5 nightly build.
I get 8 fps if i do like this: http://youtu.be/yJcMInvQ1jU
Here is test file https://developer.blender.org/F124318
**System Information** Linux 64, **Blender Version** 2.70.5 nightly build. **Short description of error** I get 8 fps if i do like this: http://youtu.be/yJcMInvQ1jU Here is test file https://developer.blender.org/F124318 **Exact steps for others to reproduce the error**
Author
Member
Author
Member
Added subscriber: @PaulGeraskin
Joshua Leung was assigned by Campbell Barton 2014-05-27 03:30:53 +02:00
Added subscriber: @ideasman42
Not sure I'd consider this a bug, but functions findzero and berekeny are quite heavy here.
Its calling fcurve_eval_keyframes a lot
Attached a patch which skips complex handle calculation when there is no need. but its not really solving the problem, just a small workaround.
fcurve_skip_findzero.diff
Other possible speedups.
  • Cache result of binarysearch_bezt_index_ex, so drawing (or any other caller), which does ordered lookups can avoid doing a full binary search each time.
  • Store per-space draw-cache for evaluated fcurves, this way redraws and playback would be fast, however transforming all curves or panning would remain slow.
  • Have a maximum number of steps to show, (rather then pixels), perhaps one sample per frame (probably OK for beziers, not so nice for some easing options).
  • Use a 2D array and have a function to fill in the points, take advantage of the ability to cache lookups.
Not sure I'd consider this a bug, but functions `findzero` and `berekeny` are quite heavy here. Its calling `fcurve_eval_keyframes` a *lot* Attached a patch which skips complex handle calculation when there is no need. but its not really solving the problem, just a small workaround. [fcurve_skip_findzero.diff](https://archive.blender.org/developer/F91346/fcurve_skip_findzero.diff) Other possible speedups. * Cache result of `binarysearch_bezt_index_ex`, so drawing (or any other caller), which does ordered lookups can avoid doing a full binary search each time. * Store per-space draw-cache for evaluated fcurves, this way redraws and playback would be fast, however transforming all curves or panning would remain slow. * Have a maximum number of steps to show, (rather then pixels), perhaps one sample per frame (probably OK for beziers, not so nice for some easing options). * Use a 2D array and have a function to fill in the points, take advantage of the ability to cache lookups.
Member
Added subscriber: @totoro-4
Member
Perhaps it redraws the whole view in every frame step? It requires 25 redraws/sec... For panning, zooming, modifying the curves etc. maybe a lower rate is quite enough. Maybe you can speed up the playback also if you redraw only the changed part at the cursor (if possible).
Member
Added subscriber: @LukasTonne
Member
I noticed that the fps issue becomes a lot worse for small x-axis intervals (zooming in on frames) - which seems odd given that this would contain a lot less frames and thus should require fewer fcurve evals. Zooming out OTOH gives fluid framerates.
Member
@LukasTonne:
The reason is that when zoomed in, it needs to sample the curve many more times to fill the gaps between keyframes, while when zoomed out, we can just plot the keyframes and be done.
As for fixing this, I'm currently leaning towards the following option:
For the majority of cases, it would be nice to move back to using the old sample-free code for the segments where actually sampling isn't necessary. That should resolve the performance problems for most users most of the time that this generally isn't a big issue. Sure, the issues still exist when dealing with fancy curves, but at least in the foreseeable future, these won't be such a big deal yet.
I'm personally not fond of using any form of caches anywhere - at least until we've completely and thoroughly exhausted every other alternative. They are a pain to get working seamlessly - our buggered pointcaches are one of the many examples of how this can go so wrong.
@LukasTonne: The reason is that when zoomed in, it needs to sample the curve many more times to fill the gaps between keyframes, while when zoomed out, we can just plot the keyframes and be done. As for fixing this, I'm currently leaning towards the following option: For the majority of cases, it would be nice to move back to using the old sample-free code for the segments where actually sampling isn't necessary. That should resolve the performance problems for most users most of the time that this generally isn't a big issue. Sure, the issues still exist when dealing with fancy curves, but at least in the foreseeable future, these won't be such a big deal yet. I'm personally not fond of using any form of caches anywhere - at least until we've completely and thoroughly exhausted every other alternative. They are a pain to get working seamlessly - our buggered pointcaches are one of the many examples of how this can go so wrong.
Member
Also, maybe if you zoom out it is not necessary to refresh at each frames, only when the cursor really moves (when 1 pixel > 1 frame)
This issue was referenced by f0a2e714b3
This issue was referenced by f0a2e714b3c0149c02014d2735e713b9b1b81eff
Member
Member
Closed by commit f0a2e714b3.
Author
Member
Thanks!
Thanks!
Author
Member
character_test_fps.blend
I removed the file from the dropbox. i attached here it for any cases.
[character_test_fps.blend](https://archive.blender.org/developer/F124318/character_test_fps.blend) I removed the file from the dropbox. i attached here it for any cases.
6 Participants
Reference: blender/blender#40372
