Cycles Does not with 2.70 90db85a Daily Build but does for 2.70A with AMD OpenCL Driver 14.6 ver1 #40399
Closed
opened 2014-05-28 03:28:12 +02:00 by Jeffrey Engelstad · 21 comments
Windows 8.1
Asus Crosshair V
AMD FX-8150 CPU
32GB DDR3 Ram
Saphire 7970 Toxic 6gbram
Broken: 2.70 90db85a
Worked: 2.70a 64bit
Don't know if this is the place for this info but
if you install AMD DRiver 14.6 ver:1 and then edit the Kernel_types.h file and un-comment all the parts under AMD Opencl
and Save.
Run Blender 2.70a Open the Mikepen BMW file switch to cycles enable im my case Tahiti for the openCL Device.
change from CPU to GPU compute, now hit render.
Compile time takes 10sec render takes 32sec.
do the same for Blender 2.70 90db85a Compile fails over 100 errors in console.
BMW1M-MikePan.blend
**System Information** Windows 8.1 Asus Crosshair V AMD FX-8150 CPU 32GB DDR3 Ram Saphire 7970 Toxic 6gbram **Blender Version** Broken: 2.70 90db85a Worked: 2.70a 64bit Don't know if this is the place for this info but if you install AMD DRiver 14.6 ver:1 and then edit the Kernel_types.h file and un-comment all the parts under AMD Opencl and Save. Run Blender 2.70a Open the Mikepen BMW file switch to cycles enable im my case Tahiti for the openCL Device. change from CPU to GPU compute, now hit render. Compile time takes 10sec render takes 32sec. do the same for Blender 2.70 90db85a Compile fails over 100 errors in console. [BMW1M-MikePan.blend](https://archive.blender.org/developer/F91654/BMW1M-MikePan.blend)
Added subscriber: @JeffreyEngelstad
Bastien Montagne self-assigned this 2014-05-28 05:45:21 +02:00
OpenCL kernel is not supported officially, and still in development. Thanks for the report, but we do not accept bug reports about it currently.
ah ok.
well I hope someday I can use my video card for rendering.
I don't wan't to sound rude but I will.
as a supporter of Blender and a Blender cloud member.
I feel I just got told to go fined a hole to shove myself in.
I understand what you are saying but you could have been a little more polite.
ah ok. well I hope someday I can use my video card for rendering. I don't wan't to sound rude but I will. as a supporter of Blender and a Blender cloud member. I feel I just got told to go fined a hole to shove myself in. I understand what you are saying but you could have been a little more polite.
Can you point me what you find impolite in this answer?
> OpenCL kernel is not supported officially, and still in development. Thanks for the report, but we do not accept bug reports about it currently. Can you point me what you find impolite in this answer?
Attaching the error log with the 100 errors might help, maybe it's easy to fix, but as mont said, we do not support OpenCL officially due to AMD driver restrictions.
It feels a little Curt.
and the fact that the end basically to me seem as if you don't care it works or not.
it could have been just arranged a little different.
Thank you for the report, But at this time we do not Officially Support the OpenCL Kernel. It is still in Development once it is complete we will accept Bug Reports
but not at this time.
I hope the way I worded that is true? is the OpenCL Kernel going to get worked on? or did I get the correct outcome out of your reply?
I know I don't relay matter as just one guy. and I am sorry for taking to much of your time already
It feels a little Curt. and the fact that the end basically to me seem as if you don't care it works or not. it could have been just arranged a little different. Thank you for the report, But at this time we do not Officially Support the OpenCL Kernel. It is still in Development once it is complete we will accept Bug Reports but not at this time. I hope the way I worded that is true? is the OpenCL Kernel going to get worked on? or did I get the correct outcome out of your reply? I know I don't relay matter as just one guy. and I am sorry for taking to much of your time already ```
that is why I posted this
dingto
it works... with Blender 2.70a all options enabled in Kernel_Types.h for AMD_Opencl
New AMD Driver 14.6 ver 1
that is why I posted this dingto it works... with Blender 2.70a all options enabled in Kernel_Types.h for AMD_Opencl New AMD Driver 14.6 ver 1
The problem is not so much on our end, but more on AMDs side. They are just incapable of delivering a working driver/compiler, which can handle complex OpenCL programs!
Yeah, then please attach the 100 errors, I cannot guess what's wrong.
how do I get a copy of the log from console?
I have been Trying to fined ways to help with this for some time.
I have spent countless hours trying to get AMDs CODE XL to debug where they are having problems, but I have not had a lot of luck. I will try again now that the kernel compiles.
how do I get a copy of the log from console? I have been Trying to fined ways to help with this for some time. I have spent countless hours trying to get AMDs CODE XL to debug where they are having problems, but I have not had a lot of luck. I will try again now that the kernel compiles.
See here about our current OpenCL status: http://wiki.blender.org/index.php?title=OpenCL
Just copy the errors from the console, right click -> copy. Then mark the errors and press Enter to copy.
See here about our current OpenCL status: http://wiki.blender.org/index.php?title=OpenCL Just copy the errors from the console, right click -> copy. Then mark the errors and press Enter to copy.
      return;
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43727: error:
        expected a declaration
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43751: warning:
        parsing restarts here after previous syntax error
              shader_eval_displacement(kg, &sd, SHADER_CONTEXT_MAIN);
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: warning: this
        declaration has no storage class or type specifier
              out = sd.P - P;
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: error: global
        variable must be declared in addrSpace constant
              out = sd.P - P;
        variable "out" has already been initialized
              out = sd.P - P;
        expression must have struct or union type
              out = sd.P - P;
        expression must have a constant value
              out = sd.P - P;
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43753: error:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43776: warning:
              int flag = 0; /* we can't know which type of BSDF this is for */
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: warning: this
              out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: error: global
        function call is not allowed in a constant expression
        identifier "flag" is undefined
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43778: error:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43781: warning:
      output[i] = make_float4(out.x, out.y, out.z, 0.0f);
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43782: error:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44074: warning:
KERNEL_TEX(float4, texture_float4, __bvh_nodes)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44075: warning: this
KERNEL_TEX(float4, texture_float4, __tri_woop)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44075: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44076: warning: this
KERNEL_TEX(uint, texture_uint, __prim_type)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44076: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44077: warning: this
KERNEL_TEX(uint, texture_uint, __prim_visibility)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44077: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44078: warning: this
KERNEL_TEX(uint, texture_uint, __prim_index)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44078: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44079: warning: this
KERNEL_TEX(uint, texture_uint, __prim_object)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44079: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44080: warning: this
KERNEL_TEX(uint, texture_uint, __object_node)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44080: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44083: warning: this
KERNEL_TEX(float4, texture_float4, __objects)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44083: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44084: warning: this
KERNEL_TEX(float4, texture_float4, __objects_vector)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44084: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44087: warning: this
KERNEL_TEX(float4, texture_float4, __tri_normal)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44087: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44088: warning: this
KERNEL_TEX(float4, texture_float4, __tri_vnormal)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44088: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44089: warning: this
KERNEL_TEX(float4, texture_float4, __tri_vindex)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44089: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44090: warning: this
KERNEL_TEX(float4, texture_float4, __tri_verts)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44090: error: global
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44093: warning: this
KERNEL_TEX(float4, texture_float4, __curves)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44093: error: global
Error limit reached.
100 errors detected in the compilation of "C:\Users\JAXOM_~1\AppData\Local\Temp
OCL3936T5.cl".
Compilation terminated.
Frontend phase failed compilation.
OpenCL build failed: errors in console
read exr tmp file: C:\Users\JAXOM_~1\AppData\Local\Temp\BMW1M-MikePan.blend_Scen
e_RenderLayer_3936.exr
``` return; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43727: error: ``` expected a declaration } ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43751: warning: ``` parsing restarts here after previous syntax error shader_eval_displacement(kg, &sd, SHADER_CONTEXT_MAIN); ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: warning: this ``` declaration has no storage class or type specifier out = sd.P - P; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: error: global ``` variable must be declared in addrSpace constant out = sd.P - P; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: error: ``` variable "out" has already been initialized out = sd.P - P; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: error: ``` expression must have struct or union type out = sd.P - P; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43752: error: ``` expression must have a constant value out = sd.P - P; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43753: error: ``` expected a declaration } ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43776: warning: ``` parsing restarts here after previous syntax error int flag = 0; /* we can't know which type of BSDF this is for */ ``` ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: warning: this ``` declaration has no storage class or type specifier out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN) ``` ; ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: error: global ``` variable must be declared in addrSpace constant out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN) ``` ; ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: error: ``` variable "out" has already been initialized out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN) ``` ; ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: error: ``` function call is not allowed in a constant expression out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN) ``` ; ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43777: error: ``` identifier "flag" is undefined out = shader_eval_background(kg, &sd, flag, SHADER_CONTEXT_MAIN) ``` ; ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43778: error: ``` expected a declaration } ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43781: warning: ``` parsing restarts here after previous syntax error output[i] = make_float4(out.x, out.y, out.z, 0.0f); ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 43782: error: ``` expected a declaration } ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44074: warning: ``` parsing restarts here after previous syntax error KERNEL_TEX(float4, texture_float4, __bvh_nodes) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44075: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __tri_woop) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44075: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __tri_woop) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44075: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __tri_woop) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44076: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(uint, texture_uint, __prim_type) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44076: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(uint, texture_uint, __prim_type) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44076: error: ``` expected a ";" KERNEL_TEX(uint, texture_uint, __prim_type) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44077: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(uint, texture_uint, __prim_visibility) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44077: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(uint, texture_uint, __prim_visibility) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44077: error: ``` expected a ";" KERNEL_TEX(uint, texture_uint, __prim_visibility) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44078: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(uint, texture_uint, __prim_index) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44078: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(uint, texture_uint, __prim_index) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44078: error: ``` expected a ";" KERNEL_TEX(uint, texture_uint, __prim_index) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44079: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(uint, texture_uint, __prim_object) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44079: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(uint, texture_uint, __prim_object) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44079: error: ``` expected a ";" KERNEL_TEX(uint, texture_uint, __prim_object) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44080: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(uint, texture_uint, __object_node) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44080: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(uint, texture_uint, __object_node) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44080: error: ``` expected a ";" KERNEL_TEX(uint, texture_uint, __object_node) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44083: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __objects) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44083: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __objects) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44083: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __objects) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44084: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __objects_vector) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44084: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __objects_vector) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44084: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __objects_vector) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44087: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __tri_normal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44087: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __tri_normal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44087: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __tri_normal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44088: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __tri_vnormal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44088: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __tri_vnormal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44088: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __tri_vnormal) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44089: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __tri_vindex) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44089: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __tri_vindex) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44089: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __tri_vindex) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44090: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __tri_verts) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44090: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __tri_verts) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44090: error: ``` expected a ";" KERNEL_TEX(float4, texture_float4, __tri_verts) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44093: warning: this ``` declaration has no storage class or type specifier KERNEL_TEX(float4, texture_float4, __curves) ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL3936T5.cl", line 44093: error: global ``` variable must be declared in addrSpace constant KERNEL_TEX(float4, texture_float4, __curves) ^ ``` Error limit reached. 100 errors detected in the compilation of "C:\Users\JAXOM_~1\AppData\Local\Temp\ OCL3936T5.cl". Compilation terminated. Frontend phase failed compilation. OpenCL build failed: errors in console read exr tmp file: C:\Users\JAXOM_~1\AppData\Local\Temp\BMW1M-MikePan.blend_Scen e_RenderLayer_3936.exr
here is what I get with Blender 2.70a.
Read new prefs: C:\Users\jaxom_000\AppData\Roaming\Blender Foundation\Blender\2.
70\config\userpref.blend
found bundled python: C:\Users\jaxom_000\Downloads\blender-2.70a-windows64\blend
er-2.70a-windows64\2.70\python
read blend: E:\Blender files\Models\refrence\BMW1M-MikePan.blend
Compiling OpenCL kernel ...
Kernel compilation finished in 10.89s.
here is what I get with Blender 2.70a. Read new prefs: C:\Users\jaxom_000\AppData\Roaming\Blender Foundation\Blender\2. 70\config\userpref.blend found bundled python: C:\Users\jaxom_000\Downloads\blender-2.70a-windows64\blend er-2.70a-windows64\2.70\python read blend: E:\Blender files\Models\refrence\BMW1M-MikePan.blend Compiling OpenCL kernel ... Kernel compilation finished in 10.89s.
This issue was referenced by 94b2852947
This issue was referenced by 94b2852947aba90850890d0b614c1684a94ab1fd
I fixed an error now, this fixes OpenCL for me on Mac OS on CPU. Please check a new build tomorrow from builder.blender.org.
Sorry it took so long to Reply but builder.blender.org did not have a new windows 64 build till today.
your fixes worked for compiling for my Opencl GPU if you don't uncomment anything in the Kernel.types.h file.
Sorry it took so long to Reply but builder.blender.org did not have a new windows 64 build till today. your fixes worked for compiling for my Opencl GPU if you don't uncomment anything in the Kernel.types.h file.
the render is fast but it takes a long time to build the Kernel.
memory usage tops out at 3.3gb if I watch task manager when cycles is compiling.
and the kernel takes 154.46sec to compile.
the pic is a re-render after the kernel was compiled to get a time on just the render.
this is at 50 samples.
![BMW1M-MikePan.blend_Opencl.png](https://archive.blender.org/developer/F92332/BMW1M-MikePan.blend_Opencl.png) the render is fast but it takes a long time to build the Kernel. memory usage tops out at 3.3gb if I watch task manager when cycles is compiling. and the kernel takes 154.46sec to compile. the pic is a re-render after the kernel was compiled to get a time on just the render. this is at 50 samples.
The Opencl Compile will work if you make the Kernel.types.h file look like this under Kernel_Opencl_AMD
  • ifdef KERNEL_OPENCL_AMD
  • define CL_USE_NATIVE
    #define KERNEL_SHADING
//__KERNEL_ADV_SHADING__
  • define MULTI_CLOSURE
  • define TRANSPARENT_SHADOWS
  • define PASSES
  • define BACKGROUND_MIS
  • define LAMP_MIS
  • define AO
    #define ANISOTROPIC
//#define __CAMERA_MOTION__
  • define OBJECT_MOTION
  • define HAIR
//end __KERNEL_ADV_SHADING__
#endif
And this is the render as you can see it works but looks strange
if you uncomment all under Kernel_Opencl_AMD in Kernel_Types.H
Build fails with the Console output looking like this.
found bundled python: C:\BlenderDaily\blender-2.70-abec198-win64-vc9\blender-2.7
0-abec198-win64-vc9\2.70\python
Device init succes
OpenCL kernel build output:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16830: error:
        identifier "__KERNEL_ADV_SHADING__" is undefined
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16841: error:
        expected a ";"
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16890: warning:
typedef uint RNG;
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18945: error:
        identifier "RNG" is undefined
ccl_device_inline float path_rng_1D(KernelGlobals *kg, RNG *rng, int sample, i
nt num_samples, int dimension)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18979: error:
ccl_device_inline void path_rng_2D(KernelGlobals *kg, RNG *rng, int sample, in
t num_samples, int dimension, float *fx, float *fy)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18996: error:
ccl_device_inline void path_rng_init(KernelGlobals *kg, ccl_global uint *rng_s
tate, int sample, int num_samples, RNG *rng, int x, int y, float *fx, float *fy)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19031: error:
ccl_device void path_rng_end(KernelGlobals *kg, ccl_global uint *rng_state, RN
G rng)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19108: error:
ccl_device_inline float path_state_rng_1D(KernelGlobals *kg, RNG *rng, PathSta
te *state, int dimension)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19113: error:
ccl_device_inline float path_state_rng_1D_for_decision(KernelGlobals *kg, RNG
*rng, PathState *state, int dimension)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19126: error:
ccl_device_inline void path_state_rng_2D(KernelGlobals *kg, RNG *rng, PathStat
e *state, int dimension, float *fx, float *fy)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19131: error:
ccl_device_inline float path_branched_rng_1D(KernelGlobals *kg, RNG *rng, Path
State *state, int branch, int num_branches, int dimension)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19136: error:
ccl_device_inline void path_branched_rng_2D(KernelGlobals *kg, RNG *rng, PathS
tate *state, int branch, int num_branches, int dimension, float *fx, float *fy)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19150: error:
ccl_device_inline uint lcg_state_init(RNG *rng, PathState *state, uint scrambl
e)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19740: error:
        invalid type conversion
              transform_motion_interpolate(&cameratoworld, (const DecompMotion
Transform*)&kernel_data.cam.motion, ray->time);
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19799: error:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19872: error:
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 41515: error:
ccl_device_inline void path_state_init(KernelGlobals *kg, PathState *state, RN
G *rng, int sample)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42144: error:
ccl_device void kernel_path_indirect(KernelGlobals *kg, RNG *rng, Ray ray,
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42388: error:
ccl_device_inline bool kernel_path_integrate_lighting(KernelGlobals *kg, RNG *
rng,
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42497: error:
ccl_device void kernel_path_ao(KernelGlobals *kg, ShaderData *sd, PathRadiance
*L, PathState *state, RNG *rng, float3 throughput)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42531: error:
ccl_device void kernel_branched_path_ao(KernelGlobals *kg, ShaderData *sd, Pat
hRadiance *L, PathState *state, RNG *rng, float3 throughput)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42614: error:
ccl_device float4 kernel_path_integrate(KernelGlobals *kg, RNG *rng, int sampl
e, Ray ray, ccl_global float *buffer)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43311: error:
ccl_device_inline void kernel_path_trace_setup(KernelGlobals *kg, ccl_global u
int *rng_state, int sample, int x, int y, RNG *rng, Ray *ray)
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43352: error:
      RNG rng;
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43427: error:
ccl_device void compute_light_pass(KernelGlobals *kg, ShaderData *sd, PathRadi
ance *L, RNG rng,
"C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43602: error:
              RNG rng = cmj_hash(i, 0);
25 errors detected in the compilation of "C:\Users\JAXOM_~1\AppData\Local\Temp\O
CL2872T5.cl".
The Opencl Compile will work if you make the Kernel.types.h file look like this under Kernel_Opencl_AMD - ifdef __KERNEL_OPENCL_AMD__ - define __CL_USE_NATIVE__ #define __KERNEL_SHADING__ ``` //__KERNEL_ADV_SHADING__ ``` - define __MULTI_CLOSURE__ - define __TRANSPARENT_SHADOWS__ - define __PASSES__ - define __BACKGROUND_MIS__ - define __LAMP_MIS__ - define __AO__ #define __ANISOTROPIC__ ``` //#define __CAMERA_MOTION__ ``` - define __OBJECT_MOTION__ - define __HAIR__ ``` //end __KERNEL_ADV_SHADING__ ``` #endif And this is the render as you can see it works but looks strange ![BMW1M-MikePan.blend_Opencl_1.png](https://archive.blender.org/developer/F92337/BMW1M-MikePan.blend_Opencl_1.png) if you uncomment all under Kernel_Opencl_AMD in Kernel_Types.H Build fails with the Console output looking like this. Read new prefs: C:\Users\jaxom_000\AppData\Roaming\Blender Foundation\Blender\2. 70\config\userpref.blend found bundled python: C:\BlenderDaily\blender-2.70-abec198-win64-vc9\blender-2.7 0-abec198-win64-vc9\2.70\python read blend: E:\Blender files\Models\refrence\BMW1M-MikePan.blend Device init succes Compiling OpenCL kernel ... OpenCL kernel build output: "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16830: error: ``` identifier "__KERNEL_ADV_SHADING__" is undefined __KERNEL_ADV_SHADING__ ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16841: error: ``` expected a ";" end __KERNEL_ADV_SHADING__ ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 16890: warning: ``` parsing restarts here after previous syntax error typedef uint RNG; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18945: error: ``` identifier "RNG" is undefined ccl_device_inline float path_rng_1D(KernelGlobals *kg, RNG *rng, int sample, i ``` nt num_samples, int dimension) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18979: error: ``` identifier "RNG" is undefined ccl_device_inline void path_rng_2D(KernelGlobals *kg, RNG *rng, int sample, in ``` t num_samples, int dimension, float *fx, float *fy) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 18996: error: ``` identifier "RNG" is undefined ccl_device_inline void path_rng_init(KernelGlobals *kg, ccl_global uint *rng_s ``` tate, int sample, int num_samples, RNG *rng, int x, int y, float *fx, float *fy) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19031: error: ``` identifier "RNG" is undefined ccl_device void path_rng_end(KernelGlobals *kg, ccl_global uint *rng_state, RN ``` G rng) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19108: error: ``` identifier "RNG" is undefined ccl_device_inline float path_state_rng_1D(KernelGlobals *kg, RNG *rng, PathSta ``` te *state, int dimension) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19113: error: ``` identifier "RNG" is undefined ccl_device_inline float path_state_rng_1D_for_decision(KernelGlobals *kg, RNG ``` *rng, PathState *state, int dimension) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19126: error: ``` identifier "RNG" is undefined ccl_device_inline void path_state_rng_2D(KernelGlobals *kg, RNG *rng, PathStat ``` e *state, int dimension, float *fx, float *fy) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19131: error: ``` identifier "RNG" is undefined ccl_device_inline float path_branched_rng_1D(KernelGlobals *kg, RNG *rng, Path ``` State *state, int branch, int num_branches, int dimension) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19136: error: ``` identifier "RNG" is undefined ccl_device_inline void path_branched_rng_2D(KernelGlobals *kg, RNG *rng, PathS ``` tate *state, int branch, int num_branches, int dimension, float *fx, float *fy) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19150: error: ``` identifier "RNG" is undefined ccl_device_inline uint lcg_state_init(RNG *rng, PathState *state, uint scrambl ``` e) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19740: error: ``` invalid type conversion transform_motion_interpolate(&cameratoworld, (const DecompMotion ``` Transform*)&kernel_data.cam.motion, ray->time); ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19799: error: ``` invalid type conversion transform_motion_interpolate(&cameratoworld, (const DecompMotion ``` Transform*)&kernel_data.cam.motion, ray->time); ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 19872: error: ``` invalid type conversion transform_motion_interpolate(&cameratoworld, (const DecompMotion ``` Transform*)&kernel_data.cam.motion, ray->time); ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 41515: error: ``` identifier "RNG" is undefined ccl_device_inline void path_state_init(KernelGlobals *kg, PathState *state, RN ``` G *rng, int sample) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42144: error: ``` identifier "RNG" is undefined ccl_device void kernel_path_indirect(KernelGlobals *kg, RNG *rng, Ray ray, ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42388: error: ``` identifier "RNG" is undefined ccl_device_inline bool kernel_path_integrate_lighting(KernelGlobals *kg, RNG * ``` rng, ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42497: error: ``` identifier "RNG" is undefined ccl_device void kernel_path_ao(KernelGlobals *kg, ShaderData *sd, PathRadiance ``` *L, PathState *state, RNG *rng, float3 throughput) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42531: error: ``` identifier "RNG" is undefined ccl_device void kernel_branched_path_ao(KernelGlobals *kg, ShaderData *sd, Pat ``` hRadiance *L, PathState *state, RNG *rng, float3 throughput) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 42614: error: ``` identifier "RNG" is undefined ccl_device float4 kernel_path_integrate(KernelGlobals *kg, RNG *rng, int sampl ``` e, Ray ray, ccl_global float *buffer) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43311: error: ``` identifier "RNG" is undefined ccl_device_inline void kernel_path_trace_setup(KernelGlobals *kg, ccl_global u ``` int *rng_state, int sample, int x, int y, RNG *rng, Ray *ray) ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43352: error: ``` identifier "RNG" is undefined RNG rng; ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43427: error: ``` identifier "RNG" is undefined ccl_device void compute_light_pass(KernelGlobals *kg, ShaderData *sd, PathRadi ``` ance *L, RNG rng, ``` ^ ``` "C:\Users\JAXOM_~1\AppData\Local\Temp\OCL2872T5.cl", line 43602: error: ``` identifier "RNG" is undefined RNG rng = cmj_hash(i, 0); ^ ``` 25 errors detected in the compilation of "C:\Users\JAXOM_~1\AppData\Local\Temp\O CL2872T5.cl". Frontend phase failed compilation. OpenCL build failed: errors in console
Reference: blender/blender#40399
