Flame/density Cycles attribute are different from 3D display
OS: Linux Mint 15 64b
CG: GTX 560Ti
Broken: Buildbot hash 09b0ead
Worked: Unknown
Smoke/fire display in viewport and density/flame attribute in cycles shader are different
See attached blend file to follow steps:
  • bake the smoke sim (would be really fast, sims take +/-30sec here)
  • go to frame 25
  • render
  • compare render result and viewport. Some smoke/fire miss on cycles render.
I join the screenshot of the blend too. Missing Smoke/fire is rounded with grease pencil on 3Dview.
Thanks a lot ! :)
boris cohen (boby) added a project: BF Blender.
boris cohen (boby) set Type to Bug.
boris cohen (boby) created this task.
boris cohen (boby) raised the priority of this task from to Needs Triage by Developer.
Thomas Dinges (dingto) triaged this task as Normal priority.
Brecht Van Lommel (brecht) closed this task as Archived.Jun 4 2014, 7:08 PM
What happens here is that you have a domain that's more than 500 units wide, while there is a rendering volume step size configured of 0.1 units. That means it will exceed the maximum 1024 volume steps, and so part of the volume will not be rendered.
You need to increase the volume steps size to see the full volume, there's no point having it so low if you use such large volume objects, it will render faster too.
