The Pink Panther - Textures in Cycles become unreadable and display pink when both OSL enabled & texture data packed #40477
2 Participants
Reference: blender/blender#40477
Broken: 2.70 & 2.71 testbuild2
Working: None
Using Cycles, when OSL is enabled (whether or not a script is in use), if you create a texture and then pack it into the file, it will render out pink. Disabling OSL will allow the texture to render just fine. This seems to occur regardless of the file type or object image is applied to (meshes, environment texture, etc.)
Note - Even if you remove the texture, object still renders pink. Not until you unpack the file or disable OSL does it render normally.
Added subscriber: @tlobes
Packed textures are not supported by OSL, this is known limitation.
Disabling OSL or unpacking would for sure fix the issue. But but what exactly means "remove the texture".?
P.S. Archiving the issue since it's just known limitation for now.
