multi-spline curve with some closed and some non-closed elements only shows closed elements; and unclosed elements are invisible in the UI unless object is selected or active #40489
Closed
opened 2014-06-03 19:48:40 +02:00 by Robert Forsman · 6 comments
*System Information
Linux bubastis 3.10.25-gentoo #10 SMP Thu Jan 30 22:17:35 UTC 2014 x86_64 Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz GenuineIntel GNU/Linux
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1) (prog-if 00 [VGA controller])
Broken: git 2c69f1e574
If a curve object consists of multiple independent bezier splines none of which are closed they are visible as 1-pixel curves in the UI.
If you change one of them to closed (use_cyclic_u=True) then the closed curves are not visible in the UI unless the object is selected or active.
To reproduce the bug create a curve and create two splines within the curve.
Make one spline closed and the other not closed.
Have the curve panel open with the Active Spline cyclic checkbox visible.
Make sure you are in object mode.
Unselect all.
toggle the cyclic checkbox repeatedly and watch how the unclosed elements of the curve disappear and reappear from the UI.
**System Information* Linux bubastis 3.10.25-gentoo #10 SMP Thu Jan 30 22:17:35 UTC 2014 x86_64 Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz GenuineIntel GNU/Linux 01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K1100M] (rev a1) (prog-if 00 [VGA controller]) **Blender Version** Broken: git 2c69f1e574587c2364e9a94b45d0b363ffeebf61 **Short description of error** If a curve object consists of multiple independent bezier splines none of which are closed they are visible as 1-pixel curves in the UI. If you change one of them to closed (use_cyclic_u=True) then the closed curves are not visible in the UI unless the object is selected or active. To reproduce the bug create a curve and create two splines within the curve. Make one spline closed and the other not closed. Have the curve panel open with the Active Spline cyclic checkbox visible. Make sure you are in object mode. Unselect all. toggle the cyclic checkbox repeatedly and watch how the unclosed elements of the curve disappear and reappear from the UI.
Author
Author
Added subscriber: @mutantbob
Author
This is a sample .blend file with a multi-spline curve that can illustrate the problem.
This issue was referenced by b3e9a71a3d
This issue was referenced by b3e9a71a3dc47900afe5bad04b810a33165fa658
Closed by commit b3e9a71a3d.
Reference: blender/blender#40489
