Holding down "R" causes rapid switching between rotate and trackball rotate
Closed, InvalidPublicTO DO
Windows 8
Broken: For every Blender version I've used, including the latest 2.70.5.
I have my hotkeys setup so pressing G/R/S activates the transform mode and letting go of G/R/S confirms. G and S keys don't have problems. However, holding down R key causes rapid switching between the regular rotate and trackball rotate modes.
My hotkey configuration for testing:
Side note: There doesn't seem to be a hotkey configuration option for activating/confirming trackball rotation.
  1. Load up my custom hotkeys.
  2. Hold down R to rotate.
KiJeon (0o00o0oo) raised the priority of this task from to 90.
KiJeon (0o00o0oo) updated the task description. (Show Details)
KiJeon (0o00o0oo) edited a custom field.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.Jun 9 2014, 9:45 AM
Campbell Barton (campbellbarton) edited a custom field.
Whoa, noticed a bug. I'm guessing it's related to this one so I didn't create a new bug item.
The [G] key also does a similar thing when held down in mesh edit mode, though I wasn't able to replicate this with any other objects.
I did find tracking markers do the same thing though.
To replicate
  1. Load my hotkey configuration.
  2. Select a mesh object and go into Edit mode.
  3. Hold down [G] and move mouse around.
also
  1. Select a tracking marker.
  2. Hold down [G] and move mouse around.
Side note
Older versions, like 2.68a did not have this problem.
Its same issue, blenders main event system doesn't detect key-repeat events, though we do for the game engine.
I wanted to further add that the rapid switching for the "G" key seems to be with the "edge slide" function. Again, this did not happen with 2.68a.
I understand this has something to do with "event system", but until that's resolved, may I suggest adding hotkey entries for trackball rotation and edge slide?
Hi,
The double tap for edge slide and trackball are both hard coded into the translate and rotate event checking code. This implementation of these features is probably not the greatest but it's what was done.
If you remove the G press key (kmi = km.keymap_items.new_modal('TRANSLATE', 'G', 'PRESS') from the transform modal map it should work as I think you want for translation in edit mode and object mode.
Unfortunately, this does not work with the rotate key because not only is it hard coded in the transform modal event handling but also in non mapped event handling of the transform operator. So even if you remove the R key binding from the modal keys it will continue to have the problem. So, one way to get what you want even with this problem is to bind the R press key of the modal map to something that doesn't do anything important while rotating, such as "Select next Edge Slide Edge". This will make sure the key is handled as a modal event but doesn't actually do anything.
Now I think you can get the behaviour you want even though it's a pretty silly method of getting there. Good luck.
Thanks for taking the time to explain, krash. I can't say I understand your instructions.. perhaps it's a bit too technical for me, but I appreciate it.
I am aware that the hotkeys are hard-coded. I listed them for T37520, which suggests removing hard-coded hotkeys altogether.
This isn't related to the custom hotkeys it happens with factory hotkeys.
Aaron Carlisle (Blendify) changed the task status from Unknown Status to Unknown Status.Jun 29 2019, 2:57 AM
Closing this is a todo, and is linked from the todo task.
