Alternating LibLoad and LibFree crashes BGE #40555
Closed
opened 2014-06-09 18:35:15 +02:00 by iPLEOMAX · 20 comments
iPLEOMAX commented 2014-06-09 18:35:15 +02:00 (Migrated from localhost:3001)
Windows 8 64-bit
Intel i3 3.4Ghz
AMD HD5650
Broken: 2.71-testbuild2
Worked: Never
This code will crash, even with delays:
library = logic.expandPath('//lib.blend')
logic.LibLoad(library, 'Scene')
logic.LibFree(library)
  1. Create a lib.blend file with a cube
  2. Create a new blend file, paste the above script and attach it to something
  3. Hit P.
Was already reported and marked as solved, but this bug still exists.
https://developer.blender.org/T40199
**System Information** Windows 8 64-bit Intel i3 3.4Ghz AMD HD5650 **Blender Version** Broken: 2.71-testbuild2 Worked: Never This code will crash, even with delays: ``` library = logic.expandPath('//lib.blend') logic.LibLoad(library, 'Scene') logic.LibFree(library) logic.LibLoad(library, 'Scene') logic.LibFree(library) ``` **Exact steps for others to reproduce the error** 1) Create a lib.blend file with a cube 2) Create a new blend file, paste the above script and attach it to something 3) Hit P. Was already reported and marked as solved, but this bug still exists. https://developer.blender.org/T40199
Author
Author
Added subscriber: @iPLEOMAX
Author
#43224 was marked as duplicate of this issue
Author
#42167 was marked as duplicate of this issue
iPLEOMAX commented 2014-06-09 18:40:58 +02:00 (Migrated from localhost:3001)
Author
Added demonstration file.
Added subscriber: @raco
It seems the crash occurs only when freeing objects that were loaded and freed once or more.
I can confirm that this also happens with LibNews of (inactive) objects, LibLoaded or not.
Edit: I was wrong. The crash occurs WHEN LOADING objects that were freed once or more.
It seems the crash occurs only when freeing objects that were loaded and freed once or more. I can confirm that this also happens with LibNews of (inactive) objects, LibLoaded or not. Edit: I was wrong. The crash occurs WHEN LOADING objects that were freed once or more.
Member
Added subscriber: @brita
Mitchell Stokes was assigned by Inês Almeida 2014-06-27 22:55:40 +02:00
Had another look at this. This may be related to #40924 because Blender only crashes if the LibLoaded object has a material.
LibLoad_LibFree_material_bug.zip
Had another look at this. This may be related to #40924 because Blender only crashes if the LibLoaded object has a material. [LibLoad_LibFree_material_bug.zip](https://archive.blender.org/developer/F96723/LibLoad_LibFree_material_bug.zip)
Added subscriber: @Moguri
Added subscriber: @mobious
The same problem occurs when using LibNew instead of LibLoad. As you can see in this file, it the crash occurs even if you load and free a different object each time. All that seems to matter is that the loaded object is using a material.
crash.blend
For me, the crash occurs on the second call to LibFree.
The same problem occurs when using LibNew instead of LibLoad. As you can see in this file, it the crash occurs even if you load and free a different object each time. All that seems to matter is that the loaded object is using a material. [crash.blend](https://archive.blender.org/developer/F115762/crash.blend) For me, the crash occurs on the second call to LibFree.
Added subscriber: @pgi
Well, I may have find an issue. It may even be the bug - who knows.
Disabling material caching prevents the crash.
My wild wild guess right now is that the pointer to the material in m_polymat_cache (KX_BlenderSceneConverter.cpp) is not released, removed, destroyed or whatever - I'm being technical here - but the pointed block is freed by LibFree (KX_BlenderSceneConverter::FreeBlendFile, perhaps :1371)
Things go on perfectly fine for a while, until the pointed block is actually recycled by the memory manager - or the name this thing has in C++.
When that happens, BANG!, the == operator in RAS_IPolyMaterial starts reading funny values and ultimately SIGSEGVs.
I'll try to see if I'm right (I'm like 50% sure about this)
Well, I may have find an issue. It may even be the bug - who knows. Disabling material caching prevents the crash. My wild wild guess right now is that the pointer to the material in m_polymat_cache (KX_BlenderSceneConverter.cpp) is not released, removed, destroyed or whatever - I'm being technical here - but the pointed block is freed by LibFree (KX_BlenderSceneConverter::FreeBlendFile, perhaps :1371) Things go on perfectly fine for a while, until the pointed block is actually recycled by the memory manager - or the name this thing has in C++. When that happens, BANG!, the == operator in RAS_IPolyMaterial starts reading funny values and ultimately SIGSEGVs. I'll try to see if I'm right (I'm like 50% sure about this)
I'm 99.9% positive on a material caching issue here. But it's a very long story.
Added subscriber: @arielvb
Author
This issue was referenced by 377822729c
This issue was referenced by 377822729cbf48d86d46f7efbae0c0e3fbeba99f
Added subscriber: @JohnDramor
Im diagnos random bug on complex scenes when libfree(). Be solve review i-- in unregister action, because unlimited loop and freezing game.
My worked sample:
		/* Now unregister actions */
			CTR_Map<STR_HashedString, void *> &mapStringToActions = scene->GetLogicManager()->GetActionMap();
			printf( " -mapStringToActions.size() start %i \n", mapStringToActions.size());
			for (int i = 0; i < mapStringToActions.size(); i++)
				ID *action = (ID*) *mapStringToActions.at(i);
				printf( " -ID *action i scene %i %i \n", mapStringToActions.size(), i);
				if (IS_TAGGED(action))
					STR_HashedString an = action->name + 2;
					mapStringToActions.remove(an);
					m_map_blender_to_gameAdtList.remove(CHashedPtr(action));
					printf( " -BUG tagged action i %i \n", i);
					//i--;
			printf( " -check here bug action unregister end....... %s \n", scene->GetName());
Im diagnos random bug on complex scenes when libfree(). Be solve review i-- in unregister action, because unlimited loop and freezing game. My worked sample: ``` /* Now unregister actions */ CTR_Map<STR_HashedString, void *> &mapStringToActions = scene->GetLogicManager()->GetActionMap(); printf( " -mapStringToActions.size() start %i \n", mapStringToActions.size()); for (int i = 0; i < mapStringToActions.size(); i++) { ID *action = (ID*) *mapStringToActions.at(i); printf( " -ID *action i scene %i %i \n", mapStringToActions.size(), i); if (IS_TAGGED(action)) { STR_HashedString an = action->name + 2; mapStringToActions.remove(an); m_map_blender_to_gameAdtList.remove(CHashedPtr(action)); printf( " -BUG tagged action i %i \n", i); //i--; } } printf( " -check here bug action unregister end....... %s \n", scene->GetName()); ```
9 Participants
Reference: blender/blender#40555
