MIP Map is generating strange noise in texture, Blender Internal.
Ubuntu 14.04, nVidia GT620
Broken: from 2.66.
Worked: 2.64 and earlier.
There's a texture with alpha (just a glow) in a plane. When MIP Maps is on, the texture is noisy. When is off, it is OK
Open the file, render the scene. Check MIPMaps off and render again.
Mario Mey (mariomey) set Type to Bug.
Mario Mey (mariomey) created this task.
Mario Mey (mariomey) raised the priority of this task from to Needs Triage by Developer.
2.65 works OK, too.
Thomas Dinges (dingto) triaged this task as Normal priority.
Campbell Barton (campbellbarton) raised the priority of this task from Normal to Confirmed, Medium.Jul 1 2014, 8:07 AM
If color slider is disabled, problem disappears at render.
If ramp is enabled in colors panel, problem disappears in texture preview, too.
@Sergey Sharybin (sergey) - Please note that the .png file that is being used to map the glow already shows signes of color banding (also known as 'stepping' and 'ringing'). This is probably being aggravated by the mapping process.
The filter also influences it.
Filter size and filter type can also make it disappear.
Looke like crappy mipmap generation, I'm on it
