Remove Level of Details command = crash
Windows 7, 64 bit
Broken: (example: 2.69.7 4b206af, see splash screen)
Blender crashes on random command
Open Blender, have no object selected or nothing in 3D view, then tap spacebar and run "Remove Level of Details". Boom, Blender crashes.
Jimmy Gunawan (enzyme69) raised the priority of this task from to 90.
Jimmy Gunawan (enzyme69) updated the task description. (Show Details)
Jimmy Gunawan (enzyme69) edited a custom field.
Thomas Dinges (dingto) changed the task status from Unknown Status to Resolved.Jun 26 2014, 11:53 PM
Closed by commit rB92ecbd2998c6.
Same happens with the Add LoD operator @Mitchell Stokes (moguri)
Maybe we should use different operator polls which check for a valid object as well. Can you take care of that?
That would fix the crash, but would not check for Objectmode anymore, not sure we need that though?
I don't think it is necessary. I experimented with adding and removing LoDs while in edit mode, and it did not appear to be a problem. To be honest, that poll method was most likely used because it was probably what the operator I was using as a reference used.
Okay, in this case, please commit your patch. :)
Daniel Stokes (kupoman) edited this Maniphest Task.Jul 2 2014, 3:13 PM
