Missing RNA Path Defines for 'rigid_body.kinematic' #40913
Reference: blender/blender#40913
Windows 8.1, nVidia GeForce GTX 770
2.71 (official) Dated: 2014-06-25 Hash:
9337574
Can't apply Keying Set that was defined by RMB Add Keying Set on the property 'Animated' in a Rigid Body setting.
The Keying Set referred to this as "rigid_body.kinematic"
I followed the steps for Method 1 listed here: http://aligorith.blogspot.com.au/2010/12/animating-in-25-getting-to-grips-with.html
I am trying to insert a key frame for the 'animated' option on a number of objects all in a group. Having defined the keying set using method 1, I tried to apply it but get the message "Keying Set failed to insert any keyframes" and, as per the blog, I'm raising this bug report because the RNA Path may not yet have been defined in Blender.
Keying Set: ButtonKeyingSet
import bpy
scene = bpy.context.scene
Keying Set Level declarations
ks = scene.keying_sets.new(idname="ButtonKeyingSet", name="AnimatedCollision Keying Set")
ks.bl_description = "Marks objects as animated in the rigid body settings"
ks.bl_options = {'INSERTKEY_VISUAL'}
ID's that are commonly used
id_0 = bpy.data.groups["03-CollissionRingRocks"]
Path Definitions
ksp = ks.paths.add(id_0, 'rigid_body.kinematic', index=0)
Added subscriber: @WazzaM
Added subscriber: @JoshuaLeung
Have you manually edited the keying set? Specifically, the ID block used (as shown above) appears to be a group, and not an object as it should be.
EDIT: Ah... I overlooked the description...
Currently, groups cannot be used to host animation data themselves, so it's not possible to have all this animation in a single action attached to the group (with paths relative to that).
If you simply want a keying set which goes through and keyframes this setting for all objects within that group (but the keyframes don't need to belong to the same action), you can implement a keying set using python as follows:
For now, I won't consider this a bug report.
However, I have noted down some todo's from this relating to groups, which will unfortunately take some time to resolve.
Hi Aligorith
You've been awesome with this so I thought I'd let you know how I went.
I tried the code fragment you gave but nothing happens because the class isn't instantiated and never gets executed when I run it through the Scripting . I've looked at keyingsets_builtins.py and I appreciate this is similar to the builtin keyingsets and should plug in somehow but I'm not sure what to do next.
I have found I can create the keyframes via scripting (no keying sets though) using this code below but I'm trying to create two keyframes and the second overwrites the first. I'll probably figure this out but it's not real clear how the index plays a part in keyframes.
This might not be your area but as some feedback on the API, it's very powerful that I get the object back when I call fcurve.new() and it would be equally cool if I got a tuple or list back when I called .keyframe_points.add(n) so I could set the frame number and value. Of course the add() function could take the frame number and value as a parameter too, to make it really friendly. I'm trying to use a -1 index on the array of keyframe_points to get the last object and update it but the overwrite is still happening so I'm making some mistake. I'll try more with it...
Path Definitions
I realised I needed to register the class you provided but get this:
Added subscriber: @AvenidaGez
I am not an expert, but working with an animation, in action editor, Usually at frame zero I do record all bones, location, rotation, scale
I do not know when it happened, but x time after working, bone head keyframe zero was not there, just one I did registered at frame 20.
So in the test, I had a jump, that is how I realized this time the bone head frame zero keyframe was missing
So I did added it again.
Tested, ok. Then of course at the end of the action, frame 320, there was a jump again because needed the copy of frame zero keyframe to cycle ok.
I added that keyframe, tested, all ok, no jumps.
Little time later, I needed to add a new bone head keyframe at frame 40, there appears the problem similar to described here
"keying set faile to insert any keyframe"
saved, reloaded, etc. the same message
So I did the same on other bones, insert a keyframe in between, this is, bones which have some keyframes betwwen start and end (320)
all, ok,
But trying in bone head failed with same message
so, a needed to insert a keyframe at frame 40, so I deleted all bones from there to the end (frame 320)
It worked, the bone head keyframe was inserted
continued working.
The message appeared again when I tried to insert a bone head in between
If I remove the frames from where I need to insert the keyframe to the end, then there is no error.
