Importing STL file fails and produces a python error - Mac #40949
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#40949
OS: Mac OSX 10.6.8 (iMac)
RAM: 8gb
Graphics card: ATI Radeon HD 5750
Broken: 2.71 official Mac version
Worked: 2.70 offical
Works also on official Windows version 2.71 running under Parallels Desktop on the same iMac.
When I try to import an STL file, an error message is produced . This originally happened when the STL file was located on a memory stick but I have also tried it when it is located on my desktop and also in my home folder - none of these work. This first happened with a file downloaded from the internet but it also occurs with a STL simple file exported from Blender itself of the default cube - both in ASCII and binary format.
P.S. First time I've reported a bug - hope I did everything correctly.
Added subscriber: @paddy10663
Added subscriber: @mont29
Not quite sure why using mmap to read a file? Looks like it’s generating some issues on OSX…
I've had a go at fixing this and it seems to work on both Windows and Mac Blender 2.71 - not tested Linux. However this is the first time I've done anything like this so I'm at a bit of a loss at what to do now; i.e. how do I submit the potentially fixed script? Could anyone help please?
@paddy10663 just place your modified addon's code here (either as a diff or just whole code), I’ll review it, test under linux, and commit if everything is OK. :)
I've attached the file with the changed code (not quite sure what a diff is or how to make one).
I've removed the use of mmap and replaced it with the 'open' command. There is also a slight increase in speed when importing stl files - in most cases negligible but nice to know.
I'll just reiterate that I am somewhat new to all this; I think I've done everything correctly but please say if I have not.
stl_utils.py
Added subscriber: @guillaum
Yep, replacing mmap stuff by mere plain open was my first idea too, then I thought author must have had some reason to use mmap… :/
Let’s give @guillaum one more week, and if no reactions I’ll simply apply that fix.
Hello,
Sorry for latency in my response.
I used MMAP because on my initials tests it was far more efficient than using many reads. (But keep in mind that my tests where on huge meshs of a few gigabytes). Also, this code was "trivially" ported from my personal base code where I was also working on STL with random access, and mmap is more efficient at random access than a bunch of read.
But if it works efficiently without mmap, of course we can remove mmap.
Good luck on that work, unfortunately I cannot contribute more to it (Time is unavailable and I cannot contribute to project related to CG because of my current work... sorry.)
Thanks @guillaum, will handle that then. :)
This issue was referenced by
a3d8d01b0e
Closed by commit
a3d8d01b0e
