"Align rotation with the snapping target" and "project individual elements" don't work together
Win7 64bit, GF 780
Broken: 81c3fc9
Worked: ?
The Object mode snapping options "Align rotation with the snapping target" and "Project individual elements" don't work together. Trying to use both at the same time results in objects being projected to the surface of the target object, but not rotated according with the surface/vertex/edge normal.
In this case one would expect each object to be aligned with the normal of the element at the projection point.
  1. Open attached file.
  2. Grab both suzannes and drag over the sphere. Observe them not being aligned to the surface.
It might be just not implemented.. @Antonis Ryakiotakis (psy-fi), you've been familiar with this code last weeks, mind having a look? Thanks!
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.Jul 14 2014, 9:19 AM
