Environment maps cause a hard crash with OSL enabled #40971
6 Participants
Reference: blender/blender#40971
Windows 8.1 Pro
Broken: 2.71 final, 2.71 RCs
Worked: unknown
Assigning World an Environment Texture results in a hard crash at render time (no crash log, no debug information in the console).
Tested and confirmed to occur with EXRs and JPGs.
Not tested with TIFFs.
Test scene: OSL_crash.blend
Added subscriber: @orcinus
#41123 was marked as duplicate of this issue
#40972 was marked as duplicate of this issue
The test EXR texture is packed in the file.
Just tested this in Blender 2.70a for Mac OS X and it works fine there.
Will test on 2.71 for Mac OS as well as 2.70 for Windows.
Added subscriber: @mont29
Can confirm crash with current master on linux64 as well :/
Does not crash on 2.71 Mac OS.
Does not crash on 2.70a Windows x64.
CRASHES on 2.70a Windows x64 VC2013 preview.
Added subscribers: @MartijnBerger, @ThomasDinges, @Sergey
The crahs of current master and packed image has been fixed. However, it's a crash on a new code which was added after 2.71 release in order to support packed images render.
Original report about crash crash of 2.71 i can not reproduce neither on linux nor on windows7. Could be something really platform-dependent like #40884.
@ThomasDinges, @MartijnBerger, are you able to reproduce crash?
@orcinus, are you able to reproduce the crahs NOT using packed images with latest builds from builder.blender.org?
◀ Merged tasks: #40972.
@Sergey The crash occurs with or without packed images. In fact, i can just leave an empty Image Texture node (without a texture loaded) connected to a shader and it will still crash.
Downloading buildbot version(s) now, will report when i test.
Just FYI, i have a strong hunch this is an interaction between Windows 8(.1) and VC2013.
If true, that might mean @mont29's linux reproduction is something else.
blender-2.71-4299b00-win64 - CRASHES
blender-2.71-81c3fc9-win64-vc9 - DOES NOT crash
By the way, note that #40884 reproduction wasn't really undertaken correctly.
The original bug was reported on Windows 8.1 (hint hint), while the OP's resolution was:
but on my main Blender station, a Windows 7 64-bit desktop with a GTX 580 GPU, the same Blender version under the same conditions does not crash
So, once again... Strong hunch this has to do with VC2013 under Windows 8(.1).
In case this helps, here are the Event Viewer crash dumps:
WER file: Report.wer
I've committed some fixed at
5e216a6
. Please grab a build which includes this commit and give it a test.Unsure how to check which build contains commits up to what, but if blender-2.71-5e3e095-win64 contains it, the problem is still there.
This build contains the fix i was referring to. Can not reproducethe crash atm tho.
@ThomasDinges, @MartijnBerger, mind having it a try?
I cannot reproduce the crash on a virtual machine where AVX is turned of even with 2.71 release.
I am thinking llvm as the real culprit
I'll merge #41123 in here since root of the issues are likely goes to the same thing.
Added subscribers: @joel.godin, @lichtwerk, @sambler
◀ Merged tasks: #41123.
Please test whether latest builds from builder.blender.org. We've upgraded both LLVM and OSL, this might have solved the issue.
Works fine now on OSX 10.9 for both this blend file and one from #41123.
Thanks.
Will assume the issue fixed now for everyone. @orcinus lemme know if it still happens for you.
@joel.godin Mac OS never exhibited the bug.
@Sergey Will retest in a few weeks (stuck on an island without access to my Windows desktop) and report back if it's still broken.
@orcinus Yes, it did if you read the bug I reported at #41123 which was merged with this one. :)
Ah, gotcha, sorry :)
Didn't experience that one.
Issue has not been fixed.
Tested with blender-2.71-526ae63-win64, same scene as posted in the original report, still crashes when you hit render or switch viewport shading to rendered.
(on Windows 8.1, as in the original report)
@orcinus, so far we can not reproduce the issue. Did you try reproducing the issue on another computer?
Yes i did.
i7 laptop (Asus Taichi) running Windows 8 (not .1) x64.
Exact same behaviour.
Have you tried reproducing it on Windows 8 (NOT 7)?
