Incorrect position of bezier point handle when set via Python #40978
Reference: blender/blender#40978
2.71
Running the code below I expect to get curve as on the left picture, but I'm getting the result from right picture. No matter what coordinates I set to "p2.handle_left" I always get same numbers for X,Y(7.91548 in case of the code below) and Z is always 0 even if I use coords like 4,1,100.
Added subscriber: @MiroHorvath
Added subscriber: @JoshuaLeung
When investigating a bug for the keyframes ui, I came across a similar problem. The bug is basically rooted in limitations in the handle recalculation code (calchandleNurb_intern()), specifically, in how it handles aligned handles recalculation.The problem is that when you've got both handles selected, it can't really figure out what to do, so it either treats it as only the first (left) handle being selected, or it gives up entirely. The workaround the keyframes UI uses now is that when editing the second handle, we ensure that only the second handle is selected when we set the value.
In other words, this will work:
This is not really a bug, more like an internal limitation, closing.
Thnx for the quick reply aligorith,
yup you're right adding p2.select_left_handle = True really does the trick.
Cheers
Added subscriber: @LukasTonne
Ok, @JoshuaLeung's explanation is totally correct. However, in a case like this the calculation order should be nicely resolvable, because only one of the handle sides is set at a time, i.e. the other side would be expected to follow it. This additional ordering information gets lost because everything uses the same generic function ...
Added subscriber: @mont29
Oops, @mont29 answered in the meantime: This solution is doing just that, only that it requires modifying selection to force the calculation order. This should not actually be necessary, but could be integrated into the rna call.
