Prefetch frames does not seem to take effect on playback #41165
Reference: blender/blender#41165
Mac OS X 10.9.4
Broken: 2.71
Editing a multi-strip project on VSE, I am not able to playback smoothly the sequence.
No matter if I change the value in Blender preferences (System - Seuqnecer/Clip Editor: Prefetch Frames), the playback hangs and even Blender become unresponsive.
By the way, the documentation (http://wiki.blender.org/index.php/Doc:2.6/Manual/Preferences/System) says that there is a limit on "System - Sequencer/Clip Editor" values. If the documentation is updated and this is still applicable, I think the controls of UI should limit the numbers. Should I open another bug for this UI issue?
Added subscriber: @jonata
Added subscriber: @mont29
Added subscribers: @Psy-Fi, @Sergey
@Psy-Fi, afair this isn't fully ported since 2.49. Mind having a glance?
Quick test with two strips here looks OK...I'd like a test file to investigate if possible.
Well, it is not that hard to reproduce. Just add a lot of strips with common effects like alpha over. The link is for a screen record of some strips playing with some video. The FPS goes to 4-7 - definitely not smooth - and you can note that when you move a strip and play, you can see... how can I say... "residual" frames that, as I understand, is a consequence of blender not pre-"fetching" the frames.
https://www.dropbox.com/s/qbceph71k2xvwot/blender-vse-test.mov
Thanks for the attention.
This looks like latency due to computation time rather than a hang. Scaling and translating an image just takes time. This is normal.
I see. So, what is "prefetch" for?
Prefetch fetches the frames of the movie itself in memory, it doesn't influence computation time due to transform operations. In the uploaded video you can clearly see that the delay occurs only while those transforms are active, not due to the movie itself.
Ok, thanks.
