Blender Crashes when UV Editing #41201
Closed
opened 2014-07-27 01:16:26 +02:00 by Gregory A Lundberg · 8 comments
Windows 8 .. if you want to know more you'll need to tell me where the heck Blender saves the Help/System Info file. You don't document it and I can't find it.
Broken: 2.71
Blender crashes when editing a UV map.
  1. Start Blender 2.71
  2. Switch to UV Editing window layout
  3. Switch to Edit mode
  4. Select Shading U/Vs tab
  5. Create a UV map. Any will do. Cube projection / Scale to Bounds works well for an example.
  6. Select ONE UV face.
  7. Enable SNAP for UV Element, select Snap to Vertex.
  8. Press G to grab/translate the selected face.
  9. Drag to snap to a vertex at another position. DO NOT FINALIZE the drag (ie, don't left-click)
  10. Be a normal user .. forget you're dragging a part of the UV map and press "A" to select all.
  11. Say "Well, damn, there goes a few hours of work!" when Blender disappears from your screen.
**System Information** Windows 8 .. if you want to know more you'll need to tell me where the heck Blender saves the Help/System Info file. You don't document it and I can't find it. **Blender Version** Broken: 2.71 Blender crashes when editing a UV map. 1) Start Blender 2.71 2) Switch to UV Editing window layout 3) Switch to Edit mode 4) Select Shading U/Vs tab 5) Create a UV map. Any will do. Cube projection / Scale to Bounds works well for an example. 6) Select ONE UV face. 7) Enable SNAP for UV Element, select Snap to Vertex. 8) Press G to grab/translate the selected face. 9) Drag to snap to a vertex at another position. DO NOT FINALIZE the drag (ie, don't left-click) 10) Be a normal user .. forget you're dragging a part of the UV map and press "A" to select all. 11) Say "Well, damn, there goes a few hours of work!" when Blender disappears from your screen.
Added subscriber: @Tad.Carlucci
Added subscriber: @kevindietrich
The "Help -> System Info" file should be in Blender! (Namely, in the Text Editor). Also be sure to always include a blendfile. Anyway, here's mine: #41201.blend
I'm getting:
Program received signal SIGSEGV, Segmentation fault.
0x0000000002954fbc in mul_v4_m4v4 (r=0x7fffffffdbf0, mat=0xc0, v=0x7fffffffdbf0) at /home/kevin/src/blender-git/blender/source/blender/blenlib/intern/math_matrix.c:522
522           r[0] = x * mat[0][0] + y * mat[1][0] + z * mat[2][0] + mat[3][0] * v[3];
And here's a backtrace: bt.txt
The "Help -> System Info" file should be in Blender! (Namely, in the Text Editor). Also be sure to always include a blendfile. Anyway, here's mine: [#41201.blend](https://archive.blender.org/developer/F99767/T41201.blend) I'm getting: ``` Program received signal SIGSEGV, Segmentation fault. 0x0000000002954fbc in mul_v4_m4v4 (r=0x7fffffffdbf0, mat=0xc0, v=0x7fffffffdbf0) at /home/kevin/src/blender-git/blender/source/blender/blenlib/intern/math_matrix.c:522 522 r[0] = x * mat[0][0] + y * mat[1][0] + z * mat[2][0] + mat[3][0] * v[3]; ``` And here's a backtrace: [bt.txt](https://archive.blender.org/developer/F99768/bt.txt)
Blender says it created a file, so I looked for a file. The web page documentation does not even mention the menu selection, much less tell you it's not really a file (that's what you mean, right?) and you'll need to open something in Blender to find it. Since I only use Blender for modelling, I have no idea where or how to open a text file, nor how to find a non-file text file created internally. I did look, first, and would have included it if I could find it.
Why include the default scene? It seems to me that every copy of Blender comes with it.
Blender says it created a file, so I looked for a file. The web page documentation does not even mention the menu selection, much less tell you it's not really a file (that's what you mean, right?) and you'll need to open something in Blender to find it. Since I only use Blender for modelling, I have no idea where or how to open a text file, nor how to find a non-file text file created internally. I did look, first, and would have included it if I could find it. Why include the default scene? It seems to me that every copy of Blender comes with it.
This issue was referenced by d49b86d0f9
This issue was referenced by d49b86d0f95117e29d107071b46dce9dbc4b2da8
Closed by commit d49b86d0f9.
Reference: blender/blender#41201
