Composite / OpenEXRMultiLayer output problem when no renderlayer is used #41301
2 Participants
Reference: blender/blender#41301
Linux Mint 14 Graphic Card: Geforce660Ti
Broken: 2.71 official (2014-06-25 18{F101314}:36 Hash
9337574
)Hi,
The render layer disappears in OpenEXRMultiLayer file when you combine two layers from a OpenEXRMultiLayer file and save it as an OpenEXRMultiLayer file.
The result is OK when you add a RenderLayer even if the render layer is not connected to the composite.
To reproduce it:
open the .blend file joined, F12 then Image/Save a copy >KO (you can see the result in the image not connected)
open the .blend file joined, add a render layer (RL1 for instance), F12 then Image/Save a copy >OK
Added subscriber: @boris.fruhauf
The results image when you add a render layer seems to be:
So as I understand:
What I wanted to do initially is to combine 2 EXR layer in one OpenEXR Multi layer file, as I understand there is not such an automatic functionality today (you can use 'File Output' node, but you will have to create a lot of inputs manually for each pass and then combine the passes from the two EXR layer).
Added subscriber: @mont29
No attached file.
EXRRL.blend
There is no bug here… If you do a compositing without any render layer, then scene itself is never rendered, and renderlayers remain empty in final multilayer EXR, that’s to be expected. Thanks for the report anyway.
