Join command is doing something else #41337
Reference: blender/blender#41337
I am going to provide a .Blend file on this. It still does it after i close and reopen.
TheFirstCar.blend
do i need the .blend1 file??
I doubt it has anything to do with the graphics card but i will note it:
Ati Mobility Radeon HD 3650 ... I am using winXP and in display properties on the advanced dialog and on Troubleshooting i have "enable write combining" unchecked. I re-checked and reboot and this issue is the same (not sure if this is the cause of the odd blender crash that occurs). I uncheck because the computer can hang from it, and the image on the screen fades.
I am told that the Join command (accessible via Object > Join) is supposed to attach two objects (eg, two cubes) so when i click on one, both highlight and it has worked.
Here i have decided to go practice and make a car. I attempted to perform the Join function on the wheels but it does three things instead.
Steps:
Select two wheels.
Go to Object and choose Join.
Response:
The two wheels selected get joined.
The other two wheels get joined.
Another pair of wheels spontaneously appear and are also joined, with one of the two in the same position as one of wheels mentioned in the above line.
Added subscriber: @Charlieb000
Added subscriber: @RJW
You have four wheel objects and each wheel is using the same mesh data (cube.002), so when you join two objects the mesh data (cube.002) becomes two wheels. The other two wheels, which use the same mesh data, therefore become two wheels each. There are several strategies to avoid this kind of thing (try asking at blender artists or blender stack exchange) but I don’t think it’s a bug.
When they were created, i created the axel then one wheel, then duplicated the wheel, then i duplicated the axel with wheels. I had the lot attached to the body at one stage then i separated them to change the wheel diameter, I tried various ways to change the diameter but they flew from the body so i did them one by one. I was then going to join them and the body together again and be done with it, but it does this. Interestingly it does similar nomatter which pair you choose, and selecting a diagonal pair gives a slightly different effect.
There is a block between the front and back wheels (lets call them tanks), these are not joined either. Try attaching those. The faces turn inside out on one. Joining the wheels to the tanks causes the wheels to go inside out and one of the tanks also (this depends on which tank was last selected). The second tank was created as a mirror of the first.
I dont think the extra joining and clone is useful in any way (especially as one step) and i wonder why any sane programmer would want to make it do that ! Plus the output is seemingly random.
Bug current at V2.71.
@RJW said it all.
I really suggest you stop this bug report flooding and first check on user-support area (like BlenderArtists forum) your issues actually are bugs before reporting them. Once again, this tracker is not a user support platform.
Steps to produce the second anomaly: (inside out)
Please make sure you have backface culling checked so you can see it.
My start up file has a singualr cube
Duplicate it
go to edit mode and pull a corner
go to object mode and duplicate it
choose mirror on one of them to cause corner to point oppositely
choose join. One goes inside out (or, one not inside out - depending on which object has priority in the selection)
I suspect the first anomaly type occured because of one of the things i tried to make them modify in sync (analysing the blender file given should show what i actually did to them). Therefore fixing the above should also fix this.
First anomaly slightly peeked in the above demo:
choose the original cube and the mirrored object but the mirrored object has preference
choose join
morred object fine, cube gets an inside out duplicate in the same location which is joined to the mirrored object.
original cube is ignored.
