view3d.select Bug (Custom Setup)
Win7 64 Ult SP1
GeForce GTX580 1.5GB
Broken: b65a022
Worked: Never
I'm attaching a video to better demonstrate the bug.
Basically, after first use of the command view3d.select (as demonstrated in the video) to add to selection, the initial behavior is broken and the add to selection behavior is locked.
Please refer to video for better demo of the bug.
Note:
Not demonstarted in the vid, identical behavior applies across Object Mode and Edit Mode.
I'm also linking to my prefs (from the video) if you guys need it to test this behavior.
Note: Deleted CGCookie Retopology tools from the prefs as they are a paid Addon (you might get an error about that)
Video:
http://edge-loop.com/images/blender/bugtracker/BlenderSelectBug.avi
Prefs:
http://edge-loop.com/images/blender/bugtracker/2.71.zip
Described in the video
Commits
rB513b8ddf0624: Fix T41421
0rAngE (undo) raised the priority of this task from to Needs Triage by Developer.
0rAngE (undo) updated the task description. (Show Details)
0rAngE (undo) added a project: BF Blender.
0rAngE (undo) set Type to Bug.
0rAngE (undo) added a subscriber: 0rAngE (undo).
Looks like this is by design see https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/space_view3d/view3d_select.c$1574 . We actually require the user to click two times on the same object, once to select and once to actually toggle.
Removing the conditional makes this behave as expected but I find this weird.
I think this happens because it's difficult then to see what the active object is? But I'll have to check with others if this is really considered bug..
Antony Riakiotakis (psy-fi) claimed this task.
Looks like this works as intended...You need to press shift select twice on an object to deselect.
The toggle select is fine.
My problem is the first time, after opening blender, if I use Shift to add to selection - it starts behaving like Shift is always pressed.
If you refer back to the video, initially (before I press Shift for the first time) when selecting a new object the old one gets deselected. That behavior gets broken once I use Shift to add to selection. From there on, selecting a new object does not deselect the old one ... it's as if Shift is always pressed from there on.
I hope this additional information helps.
That looks like a bug, I'll test to see.
Seeing 'Resolved' and 'Commit', does this mean you actually tracked it down and fixed it?!
If so, MANY Thanks!!!!!
Much appreciated.
It's something that was breaking my workflow as I had to use 'A' to deselect all the time (after the first time I would use shift to add to selection).
This behavior was also present in Edit Mode. Pretty much the same thing as Objects, but on subObject level.
Yes, it should be fixed...I suspect issue might be deeper here, but I'll have to check with other developers
Thought I'd post back.
I've tried a recent build from graphicall and you've nailed it!!!
It's not happening any more. Fixed both in Object and Edit Mode.
Much appreciated.
You rock Antony!!!
