floating menus - scroll issues
Win7x64 GTX660M
Broken: 2.71.3
Scroll arrows on search floating panel dont work.
Just hit spacebar on 3dview and try to scroll entries using scroll arrows.
This is working fine on menu entries like specials in edit mode
(make blender window small enouch to test it)
Related Objects
Czarek Kopias (kopias) raised the priority of this task from to Needs Triage by Developer.
Czarek Kopias (kopias) updated the task description. (Show Details)
Czarek Kopias (kopias) set Type to Bug.
Think this never worked this way in this case, arrows are only here to indicate you have other invisible items afaik?
Anyway, there is another issue here, which is scrolling with mouse wheel does not work anymore - this might be another glitch from the 'autodefault' new feature, Campbell, so assigning that report to you for now.
Bastien Montagne (mont29) renamed this task from search floating panel scroll arrows to search floating panel - scroll issues.Aug 15 2014, 2:38 PM
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.
Bastien Montagne (mont29) renamed this task from search floating panel - scroll issues to floating menus - scroll issues.Aug 16 2014, 2:45 PM
◀ Merged tasks: T41461.
Yes, arrows were never clickable, but the scroll wheel selection worked up to the last stable 270a. To reiterate what I said in T41461(so you don't have to look there too), the scroll wheel selection now only works when the mouse is in the text entry field, not anywhere in the menu.
It just needs to work like face menu in edit mode:
As a workaround, you can scroll the list using up/down arrows on your keyboard.
I am wondering if it is not a kind of new UI paradigm choïce.
