Vector pass errors with animated array, curve and subsurf modifier combined #41430
2 Participants
Reference: blender/blender#41430
Windows 7 64-bit, nvidia gtx 570
Broken: official 2.71 (
9337574
) and latest 64-bit build (7c9b8aa
)Worked: -
Using a specific combination of modifiers and keyframes the vector pass displays errors using Cycles, with the vector pass being displayed as a patchwork of faces instead of solid objects.
Using an array modifier, a curve modifier and then a subsurf modifier AND having kefyrames on the array's 'count' value causes this error to appear. Remove any one of the modifiers or the keyframes or remove the curve used by the curve modifier and the error does not appear.
The object has a 90 degree rotation animation just to get some vector data to appear.
Happens with both GPU and CPU render.
Just render this file to see the effect: vector_animated_array_bug.blend:
Or just view this render:
To reproduce effect:
Added subscriber: @RayMairlot
Quite extreme case, will have a look, maybe it's solvable.
So the issue is that you actually modifying the geometry by the keyframes. In this case it's not really possible to distinguish which pars of objects were moved to where (that's NP-complex problem to do such a mapping) and hence both Cycles and BI expects that's objects are not changing their topology for the vector pass.
Would be nice to support with some fancy algorithm, but that's outside of the scope of the bug tracker and considered a TODO. Thanks for the report anyway.
