When storing time.time() in a game property, the game property doesn't return the same time #41490
5 Participants
Reference: blender/blender#41490
Windows 7 x64, Intel 3000 graphics
Broken: 2.70a
f93bc76
In the game engine, when setting a game property (type float) of an object to time.time() and then printing it, it returns not the same value as you have set.
Set Blender in game engine mode
Create an object and assign it a game property named "thetime", type float
Create a sensor (always or keyboard) and a controller (python), attach them to eachother
Python code:
thetime = time.time()
print(thetime)
obj["thetime"] = thetime
print(obj["thetime"])
It looks like the object (which is basically C++ code?) is using doubles while python can only handle floats?
It does work when I convert the time to int (and also set the game property to type float)
Added subscriber: @rejhgadellaa
Added subscriber: @marcino15
Float property has limit.
If you want store exact time, you must use string property obj["thetime"] = str(thetime)
@marcino15 thanx for the quick reply. I hope you mean this to be a workaround and not a fix? :)
Python uses doubles (doesn't have floats, I mixed that up in the OP) and since the game engine uses python for programming it would make sense if the game properties are of the same type as python's types since python does not have the option to choose (thus the C/C++ side should adept).
In other words: game property floats should be of type double.
This is correct work and not need to fix.
Added subscriber: @sphaero
I tend to disagree. I think storing time as a string is indeed a workaround. I'm not sure how the the game engine handles float game properties internally but if it creates a situation likes this because of float <> double conversion it would make sense to set the float game property as a double internally.
Added subscriber: @JorgeBernalMartinez
it is not easy to increase the precision from float to double in property code. It would involve changes which affect to int and timer properties also (data variable used by int/float would have to pass to 8 bytes).
Added subscriber: @panzergame
Hello, BGE convert as much as possible properties in his own type and in this case in float. So you have to set it in a tuple to keep the precision.
I don't think that is a wrong behavior to contrain the user to use as minimum hight precision value.
