Now impossible to make negative volumes :( #41495
6 Participants
Reference: blender/blender#41495
Archlinux
GTX 460
Broken: 2.71
Worked: 2.70
The intent of the fix to #39284 seems to have been to make it harder to accidentally make a potentially confusing light-emitting volume, which makes sense.
However, it now seems impossible to get such an effect. Using negative colors as suggested doesn't seem to work, as they are now clamped as well (
77f815f67a
). Using a negative value node also doesn't seem to work.This is a cool effect, and IMO it's fine to allow negative/unusual values if they are explicitly typed in (as opposed to sliding with the mouse, where it's easy to do something accidentally).
In most places, Blender seems to go by the philosophy that the user knows what they are doing,
with well-placed exceptions for dangerous/non-reversible actions like opening a new file and losing changes to the current one, where it asks for confirmation.
Since setting a volume to be negative is easily reversible, IMO the user doesn't need as much "stupidity protection" :)
This is allowed with lamps, so I don't see the reason for disabling this on volumes.
Added subscriber: @gandalf3
Added subscriber: @Ace_Dragon
1). This isn't really a 'bug'.
2). If you use a value node hooked into a color mix node, you can still get negative color values.
3). I'm not so sure of 'stupidity protection' as it is to make sure that it's not so easy to get completely unintended, error-prone results by accident (which someone else might see as a bug). This way you have such results only present when the user intends it.
@Ace_Dragon
This seems to be working fine for lamps, so why all the clamping on volumes?
It should still be possible with OSL?
Added subscriber: @Sergey
Sergey, any strong opinion here?
Imho, the negative volume effect can be nice, but is too unpredictable to allow per default. If you want it, you can write a custom OSL shader which does not limit the color or density.
Added subscriber: @ideasman42
We can allow be explicitly setting limits so for some colors negative values are supported.
The reason I added this check is many colors could be set to negative values and really didn't do anything useful, or they gave some strange, accidental result.
So on a case-by-case basis this can be added back, but first check the math that deals with the color handles this correct.
Added subscriber: @mont29
Added subscriber: @brecht
There's no reason to keep this bug open, the fix in #39284 intentionally disabled this "feature" which the volume integrator really can't handle correctly and will cause all kinds of bugs in multiple importance sampling, render passes and so on. Negative density is non-sensical and I don't believe any user actually knows what they are doing when using negative density. We can't keep around render bugs just because they look interesting.
