Sun Beam Node has artifact at its radius.
Windows 7, 64-bit
CPU
Broken: (example: 2.69.7 4b206af, see splash screen)
blender-2.71-8bb318b-win64
The center point of the new Sun Beam Node leaves a small cube. This is very visible when the Node is used against very bright images.
Attached is a .Blend file. A quick render shows the dot in the center of the Sun Beam Node after the compositing is done.
David Brennan (davidbrennan) raised the priority of this task from to Needs Triage by Developer.
David Brennan (davidbrennan) updated the task description. (Show Details)
Sergey Sharybin (sergey) lowered the priority of this task from Needs Triage by Developer to Normal.Aug 22 2014, 11:59 AM
This seems like a "showstopper" to me. I've just been experimenting with the Sun Beam Node for hours and this makes it nearly unusable perhaps 75% of the time. (Well, it can be used, but there's all sorts of secondary steps needed to clear out that dot.) I don't believe the Sun Beam Node should be packaged if this persists in it.
