GE crashes when object from other scene is ended after adding it #41599
Closed
opened 2014-08-27 13:40:42 +02:00 by Kayran Schmidt · 17 comments
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
         Language: German (Regional Setting: German)
System Manufacturer: Hewlett-Packard
     System Model: HP Pavilion dv7 Notebook PC
             BIOS: InsydeH2O Version 03.60.48F.17
        Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
           Memory: 8192MB RAM
Available OS Memory: 8140MB RAM
        Page File: 3061MB used, 13215MB available
      Windows Dir: C:\Windows
  DirectX Version: DirectX 11
graphic cards:
Radeon (TM) HD 6490M
Mobile Intel(R) HD Graphics
official 7.1
its simple:
when the game runs a overlay scene is added
when you press enter, a textobject from a invisible layer of this overlay scene is added to the overlay scene, and has an framecount of 120 frames to disappear.
the bug:
when the ~ 2 seconds of the 120 frames are over, the program crashes,
and there is another bug related to:
the new object should be added at the coordinates of the plane present in the overlay layer, but its added somewhere else, thou every time at the same position
the script:
import bge
import GameLogic
con = bge.logic.getCurrentController()
scene = bge.logic.getCurrentScene()
ownerobject = con.owner
keyboard = bge.logic.keyboard
def main():
#a counter for time measure, it counts the logic steps
#overlay scene
  if 'addedOverlay'not in ownerobject:
      bge.logic.addScene("overlay", 1)
      ownerobject['addedOverlay'] = True
#get the scene list
  for scenex in bge.logic.getSceneList():
      ownerobject[scenex.name] = scenex
#define that on pressing enter, writemode is activated
  if keyboard.events[bge.events.ENTERKEY] == bge.logic.KX_INPUT_JUST_ACTIVATED:
      print(ownerobject["overlay"].objects)
      ownerobject["overlay"].addObject(ownerobject["overlay"].objectsInactive["commandList"], ownerobject["overlay"].objects["Plane"], 120)
main()
bug.blend
just press p and then enter
**System Information** Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144) ``` Language: German (Regional Setting: German) ``` System Manufacturer: Hewlett-Packard ``` System Model: HP Pavilion dv7 Notebook PC BIOS: InsydeH2O Version 03.60.48F.17 Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (4 CPUs), ~2.3GHz Memory: 8192MB RAM ``` Available OS Memory: 8140MB RAM ``` Page File: 3061MB used, 13215MB available Windows Dir: C:\Windows DirectX Version: DirectX 11 ``` graphic cards: Radeon (TM) HD 6490M Mobile Intel(R) HD Graphics **Blender Version** official 7.1 **Short description of error** its simple: when the game runs a overlay scene is added when you press enter, a textobject from a invisible layer of this overlay scene is added to the overlay scene, and has an framecount of 120 frames to disappear. the bug: when the ~ 2 seconds of the 120 frames are over, the program crashes, and there is another bug related to: the new object should be added at the coordinates of the plane present in the overlay layer, but its added somewhere else, thou every time at the same position the script: import bge import GameLogic con = bge.logic.getCurrentController() scene = bge.logic.getCurrentScene() ownerobject = con.owner keyboard = bge.logic.keyboard def main(): ``` ``` #a counter for time measure, it counts the logic steps ``` ``` #overlay scene ``` if 'addedOverlay'not in ownerobject: bge.logic.addScene("overlay", 1) ownerobject['addedOverlay'] = True ``` #get the scene list ``` for scenex in bge.logic.getSceneList(): ownerobject[scenex.name] = scenex ``` #define that on pressing enter, writemode is activated ``` if keyboard.events[bge.events.ENTERKEY] == bge.logic.KX_INPUT_JUST_ACTIVATED: print(ownerobject["overlay"].objects) ownerobject["overlay"].addObject(ownerobject["overlay"].objectsInactive["commandList"], ownerobject["overlay"].objects["Plane"], 120) print(ownerobject["overlay"].objects) ``` main() ``` ``` [bug.blend](https://archive.blender.org/developer/F106985/bug.blend) **Exact steps for others to reproduce the error** just press p and then enter
Author
Author
Added subscriber: @Winnetou
Author
pls do not make up your minds about the comments, i forgot to delete them, as i came across this error wehn programming a game, hence the comments
and i want to thank blender society for ever effort in advance
w
pls do not make up your minds about the comments, i forgot to delete them, as i came across this error wehn programming a game, hence the comments and i want to thank blender society for ever effort in advance w
Author
sry that i didnt write all these comments in my post, but i just discovered something interesting:
it only crashes with textobjects, cubes or anything else works fine....
sry that i didnt write all these comments in my post, but i just discovered something interesting: it only crashes with textobjects, cubes or anything else works fine....
Added subscriber: @raco
Edit:
Looking at your blend more carefully made me realize I didn't reproduce it exactly as was explained. Sorry about that. I could reproduce it and my conclusion is that adding an object in an overlay scene through the controller of an object in the background scene causes Blender to crash.
In the blend attached you can see clearly that the same script works if it's run through the controller of the spawner in the overlay scene. However, if you deactivate it in the Logic Brick editor and activate the 'add_text' brick in the background scene instead, then the crash occurs.
Overlay_scene_add_object_bug.blend
I remember this crash was discussed somewhere, so it could be that this was reported already.
Edit: Looking at your blend more carefully made me realize I didn't reproduce it exactly as was explained. Sorry about that. I could reproduce it and my conclusion is that adding an object in an overlay scene through the controller of an object in the background scene causes Blender to crash. In the blend attached you can see clearly that the same script works if it's run through the controller of the spawner in the overlay scene. However, if you deactivate it in the Logic Brick editor and activate the 'add_text' brick in the background scene instead, then the crash occurs. [Overlay_scene_add_object_bug.blend](https://archive.blender.org/developer/F107380/Overlay_scene_add_object_bug.blend) I remember this crash was discussed somewhere, so it could be that this was reported already.
Author
if it is already in discussion somewhere, i didn't find it as i searched the bug, sry
anyway, i found a other way to my goal, though,
and i am happy to had the opportunity to be part of blender developement once...
thank you for your comment
if it is already in discussion somewhere, i didn't find it as i searched the bug, sry anyway, i found a other way to my goal, though, and i am happy to had the opportunity to be part of blender developement once... thank you for your comment
Member
Added subscriber: @JorgeBernalMartinez
Member
@raco: I just checked your example and I can not reproduce the crash. In both options that you point out, I obtain the word "text" without any crash.
tested with current master (2.72RC)
@raco: I just checked your example and I can not reproduce the crash. In both options that you point out, I obtain the word "text" without any crash. tested with current master (2.72RC)
Raf Colson self-assigned this 2014-09-28 12:14:28 +02:00
Thanks lordloki. It seems to be fixed in 2.72RC.
Edit: Nope, I was wrong. Didn't test if it crashed on endObject(). But it does.
Thanks lordloki. It seems to be fixed in 2.72RC. Edit: Nope, I was wrong. Didn't test if it crashed on endObject(). But it does.
Changed status from 'Resolved' to: 'Open'
Sorry guys, it's still broken. Press Return to add object, wait a second until Blender crashes when its removed from the scene.
Overlay_scene_remove_added_object_bug.blend
Sorry guys, it's still broken. Press Return to add object, wait a second until Blender crashes when its removed from the scene. [Overlay_scene_remove_added_object_bug.blend](https://archive.blender.org/developer/F113372/Overlay_scene_remove_added_object_bug.blend)
Raf Colson removed their assignment 2014-09-28 12:26:48 +02:00
Member
@raco: I confirm the bug now :-)
Member
Jorge Bernal self-assigned this 2015-03-15 10:57:48 +01:00
Member
Added subscriber: @panzergame
Member
Closed by @panzergame commit 176ecd9c9
Thanks for reporting.
Closed by @panzergame commit 176ecd9c9 Thanks for reporting.
Reference: blender/blender#41599
