Improving the readability of vertical tabs #41697
8 Participants
Reference: blender/blender#41697
I have difficulties to read the vertical tabs text. Here is an example:
I want to propose this alternative for the default settings:
Tab Active: 7683A0
Tab Inactive: 727272
I have chosen to colorize the active tab in a very light blue to better spot it on the screen. Also it appears to me that "active" elements are normaly colorized with a Blue background. If the blue background is disliked, then i propose to use instead:
tab Active: 9A9A9A
Added subscriber: @GaiaClary
Added subscriber: @ideasman42
Not especially liking to make one tab colored as proposed.
Note that this was an issue when adding tabs and seems to depend a lot on each users monitor brightness.
There are a few things we could do to tweak current tabs.
Rather not but for completeness...
Based on previous points, heres an example
https://developer.blender.org/P134
(Also set the theme color for tab background to be
RGB=[0.386, 0.386, 0.386]
)Added subscriber: @Luarvik
Very minimalistic divider. Looks cool, but visually merge all inactive tabs to one line of text. Harder to read and locate required tab.
Considering the usage of colour for active tab - I also support this idea.
Campbell, I slightly modified your version. It still looks minimalistic but little easier to read, I hope. This is just quick draft so can be improved further.
Added subscriber: @00Ghz
I like the dark blue colored version. You can't miss the active tab in that case. But the bright yellow one is way to distracting.
Added subscriber: @michaelknubben
I'm in favour of the colour-less versions, like this one made by @Luarvik
and this one by @ideasman42
The coloured highlight should be used more sparingly, in my opinion.
I would go for spaceless tab design if you choose no color, it's easier to find the tabs for me.
Added subscriber: @PawelLyczkowski-1
As the author of the current design, I think the overall form looks good : ) (@Luarvik 's one is also nice, but less consistent with the current GUI style)
But the implementation differs from my design:
The implemented ones have obviously darker inactive tabs, as well as slight embossing (the embossing reduces the readability as well, making the text appear a bit blurry).
Also the gaps are slightly too large, but it's a minor thing.
@PawelLyczkowski-1 - can you please be a bit more explicit here since it does get a bit confusing talking about 3 designs - original/current-code/proposed
If you show an image that looks different, Im not sure which changes are incidental, and which are important (since I may not get pixel perfect match using OpenGL).
Please list significant changes in dot-point, and give some rationale for each. Then others can comment on each change, and if its agreed on, I can make up a patch.
@ideasman42 Ok, ignore my previous post - here you have a color scheme that has higher readability, and won't require big recoding I suppose:
I changed the colors of the default theme to make the tabs more readable, and still match the style of the theme. You can sample the image to get the colors I used.
Two problems here:
Not much rationale here - white text will be much more readable on both gray and dark gray, especially without the white emboss that is still in the screenshot. And it looks more consistent with the rest of theme (where "tabs" in the Properties editor are dark gray for instance).
I think it would be very helpful if text colours for active and inactive tabs could be adjusted independently in theme settings. Currently they both use "Region Text" colour.
P.S. Sorry didn't notice that Plyczkowski already had mentioned this...
The last proposed design is really visually noisy though. I don't feel this is an improvement over the currently implemented design at all.
I don't see how it's noisy, except the embossing. It's an improvement in readability, which should take precedence.
Noise is perhaps the wrong word, and I see no reason to drag this out over a matter of preference, but I feel the white on dark grey is too contrasting.
If you're still up for discussing it though, what do you dislike about @Luarvik and @ideasman42's designs? I have a preference for those.
We already have white on dark gray all over this theme.
The @ideasman42 's one read less like tabs (which cumulates with the tabs being vertical resulting in lower readability). The @Luarvik 's one looks nice, but doesn't follow the style of the rest of the GUI. I already did some designs that used square elements, like the editor type dropdowns here - https://dl.dropboxusercontent.com/u/6959287/Art/Blender%20UI%20Mockups/mockup02_03.png
If we were to refresh the GUI style in this direction, @Luarvik 's style would be the one to use for the tabs.
Ah yes, agreed. That would be outside of the scope of this task.
I don't mind at all the rounded style for tabs. The rectangular shape on my proposal was just a try to keep it as minimalistic as possible. What I mind though is a divider between inactive tabs to look like "l" letter.
Added subscriber: @JannisAdamek
Hi,
I am new to the development page and very interested in the tap topic. Yesterday I read all the UI-topics and now I am very exicted about all the work.
Plyczkowski made a very good job designing the tabs but the picture on the left looks sill way better (how to add pictures :P). It saves space and has more contrast. When having muliple editors on the screen I sometimes have to scroll through the taps when I'm working on a laptop for example. The look is just smoother as well.
Added subscriber: @JonathanWilliamson
Archiving for inactivity.
