Node wrangler does not ignore hidden sockets
Archlinux
GTX 460
Broken: d42c085
Shift clicking a node with hidden sockets will still connect those hidden sockets to the output node.
  1. Add a node with a lot of sockets (e.g. a texture coordinate node)
  2. Press Ctrl H to hide the nodes sockets
  3. Shift click the node. Hidden sockets will be connected.
Ellwood Zwovic (gandalf3) updated the task description. (Show Details)
Ellwood Zwovic (gandalf3) raised the priority of this task from to Needs Triage by Developer.
Ellwood Zwovic (gandalf3) set Type to Bug.
Sorry, did not saw it was about an addon at first.
Btw, other issue with this addon - seems to always assume to be in Cycles materials nodes (adds Cycles' output node even when editing internal nodal material!).
Got it. I will take care about it shortly.
At first I will fix behavior with hidden sockets.
As for material nodes for Blender Render: The add-on is not intended for material nodes in Blender Render. I will add restriction that will disable it when working with Blender Render material nodes.
Bastien Montagne (mont29) triaged this task as Normal priority.Sep 10 2014, 10:31 AM
Thanks Bartek! :)
Fixed. Thanks for pointing those bugs out.
