addon Mesh:Extra Tools operator Add Armature is flaky #41775
Closed
opened 2014-09-10 20:05:50 +02:00 by Robert Forsman · 12 comments
Broken: 2.71
meta-andoctro on IRC asked me to help find out what is wrong with the Mesh: Extra Tools Multi Face Extrude / Add Armature tool. I have managed to confuse myself.
start with the default cube.
go to the addons tab in the Tool region and chose Multi Face Extrude from the Multi Extrude Plus panel
Without doing anything else, click the Add Armature button.
The operator will fail with a "Select a face or a vertex where the chain should end..." error message.
According to meta-andoctro this workflow used to work in the past. I'll let him provide more detail.
**Blender Version** Broken: 2.71 **Short description of error** meta-andoctro on IRC asked me to help find out what is wrong with the Mesh: Extra Tools Multi Face Extrude / Add Armature tool. I have managed to confuse myself. **Exact steps for others to reproduce the error** start with the default cube. go to the addons tab in the Tool region and chose Multi Face Extrude from the Multi Extrude Plus panel Without doing anything else, click the Add Armature button. The operator will fail with a "Select a face or a vertex where the chain should end..." error message. According to meta-andoctro this workflow used to work in the past. I'll let him provide more detail.
Author
Author
Added subscriber: @mutantbob
Author
Since the Add Armature operator requires you to select some faces, I jumped to the conclusion that the Multi Face Extrude should complete its operation leaving the tips of the extrusions selected.
The following patch seems to accomplish that.
diff --git a/mesh_extra_tools/mesh_mextrude_plus.py b/mesh_extra_tools/mesh_mextrude_plus.py
index ed0ab86..c855f07 100644
--- a/mesh_extra_tools/mesh_mextrude_plus.py
+++ b/mesh_extra_tools/mesh_mextrude_plus.py
@@ -131,6 +131,8 @@ class MExtrude(bpy.types.Operator):
         bm.from_mesh(obj.data)
         sel = [f for f in bm.faces if f.select]
+        after = []
         # faces loop
         for i, of in enumerate(sel):
             rot = vrot(self, i)
@@ -159,9 +161,14 @@ class MExtrude(bpy.types.Operator):
                 bm.faces.remove(of)
                 of = nf
+            after.append(of)
         for v in bm.verts: v.select = False
         for e in bm.edges: e.select = False
+        for f in after:
+            f.select = True
         bm.to_mesh(obj.data)
         obj.data.update()
Unfortunately, while this alteration does allow the Add Armature button to succeed, something weird is going on with the parameters region for the Add Armature operator. Adjusting any of the parameters (such as Max Bones) resets the mesh to the state before Multi Face Extrude was clicked.
If you do any other operation between Multi Face Extrude and Add Armature (such as toggling to edit mode) then the problem does not exhibit itself.
My grip on how adjustments to these operator parameters are handled in the state and the UI is nonexistent, so I'm going to need some help to create a "boundary" between the two operators.
Since the Add Armature operator requires you to select some faces, I jumped to the conclusion that the Multi Face Extrude should complete its operation leaving the tips of the extrusions selected. The following patch seems to accomplish that. ``` diff --git a/mesh_extra_tools/mesh_mextrude_plus.py b/mesh_extra_tools/mesh_mextrude_plus.py index ed0ab86..c855f07 100644 --- a/mesh_extra_tools/mesh_mextrude_plus.py +++ b/mesh_extra_tools/mesh_mextrude_plus.py @@ -131,6 +131,8 @@ class MExtrude(bpy.types.Operator): bm.from_mesh(obj.data) sel = [f for f in bm.faces if f.select] + after = [] + # faces loop for i, of in enumerate(sel): rot = vrot(self, i) @@ -159,9 +161,14 @@ class MExtrude(bpy.types.Operator): bm.faces.remove(of) of = nf + after.append(of) for v in bm.verts: v.select = False for e in bm.edges: e.select = False + + for f in after: + f.select = True + bm.to_mesh(obj.data) obj.data.update() ``` Unfortunately, while this alteration does allow the Add Armature button to succeed, something weird is going on with the parameters region for the Add Armature operator. Adjusting any of the parameters (such as Max Bones) resets the mesh to the state before Multi Face Extrude was clicked. If you do any other operation between Multi Face Extrude and Add Armature (such as toggling to edit mode) then the problem does not exhibit itself. My grip on how adjustments to these operator parameters are handled in the state and the UI is nonexistent, so I'm going to need some help to create a "boundary" between the two operators.
Brendon Murphy was assigned by Bastien Montagne 2014-09-11 08:18:38 +02:00
Member
hi, I've been aware of this issue & I am trying to fix with little success atm.
It may be that I will have to remove if it cannot be fixed properly within a few weeks.
Thanks mutantbob for the multi extrude fix, I will look at that too.
I',m really not sure what caused these issues as these two addons worked perfectly in 2.63 without the need for selected end face.
Thanks for report & help.
hi, I've been aware of this issue & I am trying to fix with little success atm. It may be that I will have to remove if it cannot be fixed properly within a few weeks. Thanks mutantbob for the multi extrude fix, I will look at that too. I',m really not sure what caused these issues as these two addons worked perfectly in 2.63 without the need for selected end face. Thanks for report & help.
Member
committed part on of the fix, by mutantbob
fix for last face selected thanks purplefrog
blender/blender-addons-contrib@ea70fe1bab
I have a test version of the addon (parent addon mesh_extra tools) with add armature removed.
I'll allow some more time to try to fix before removing add armature & closing this report.
committed part on of the fix, by mutantbob fix for last face selected thanks purplefrog blender/blender-addons-contrib@ea70fe1bab I have a test version of the addon (parent addon mesh_extra tools) with add armature removed. I'll allow some more time to try to fix before removing add armature & closing this report.
Author
The problem with the armature is definitely related to the undo system.
If you do
Multi Face Extrude
Add Armature
then it undo-s both of the operations, not just the Add Armature.
I'm inclined to blame the undo system for the time being.
The problem with the armature is definitely related to the undo system. If you do Multi Face Extrude Add Armature Undo then it undo-s both of the operations, not just the Add Armature. I'm inclined to blame the undo system for the time being.
Member
hi, the current problem with the armature code is the length of the bones, when the addon was working it followed edge loops nicely, now the bone length is incorrect.
Added subscriber: @Praful
Added subscriber: @Praharshita
Member
hi,
only a few days to go, if anyone can fix the armature length issue, please do, if not, we lose this feature.
hi, only a few days to go, if anyone can fix the armature length issue, please do, if not, we lose this feature.
Member
Member
removed armature function from menu.
Reference: blender/blender-addons#41775
