Sculpt Symmetry Broken with Clipping Border
Closed, InvalidPublic
Win7 64 Ult
GeForce GTX 580, 1.5GB
Broken: Latest Buildbots (for sure)
Worked: I think it was always broken
The symmetry in Sculpting is broken if you use Clipping Border
Add any object
Go to Sculpting
Enable Symmetry: X
Sculpt. Everything is OK
View > Clipping Border - draw a border only on one side
Sculpt. Symmetry is broken
0rAngE (undo) raised the priority of this task from to Needs Triage by Developer.
0rAngE (undo) updated the task description. (Show Details)
0rAngE (undo) added a project: BF Blender.
0rAngE (undo) set Type to Bug.
0rAngE (undo) added a subscriber: 0rAngE (undo).
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.Sep 19 2014, 9:59 PM
This is a dreaded case of "works as expected I'm afraid"
Too bad.
I started to use Clipping Border more frequently when sculpting to handle tough spots when using Grab/SnakeHook.
That's when I actually pinpointed it breaks the symmetry.
You can work around it, as long as you know it's gonna break symmetry.
Try to keep it in mind if anyone gets the time to look through the issue.
I'll give you guys a reminder in ~6 months.
