env map bump #41901
2 Participants
Reference: blender/blender#41901
windows7 64
ASUS ATI Radeon HD6870
Broken: (All)
Worked: (None)
open this and go to rendered shading mode or press F12
env_map_bump.blend
P.S. in all other influence functions working properly
Added subscriber: @Inwader77
Well, it's probably just another design limitation of BI, but will have a closer look anyway.
And else, if we open pre - baked env map and switch on bump - we will have this bug again
Using image as a bump map works correct here. Also using the envmap as a bump map does what it was intended to do from the code point of view -- it's all how the derivatives are calculated. Plus in a different from image bump maps RGB are not used for this, the intensity returned by the procedural texture is used. So this is why you've got the bumps only on the bounds of the "cells".
Thing could be changed, but it's also gonna to break compatibility and so.Just bake your textures for now.
