Shortcut to simplify subdiviision levels!
Please put a shortcut available for the subdivision limitator of a scene! It is not possible to assign, and would be very handy!
Ivam Pretti (ivampretti) updated the task description. (Show Details)
Ivam Pretti (ivampretti) raised the priority of this task from to Needs Triage.
Ivam Pretti (ivampretti) set Type to To Do.
Sergey Sharybin (sergey) closed this task as Archived.Sep 29 2014, 10:02 AM
Sergey Sharybin (sergey) claimed this task.
If i understand you correct, it is possible by using bpy.ops.wm.context_set_int with a path of "scene.render.simplify_subdivision". So for the custom keymap you can easily do that, no need to change anything in upstream i think.
Thanks for the report, but closing it now.
could you be more especific? I tried this comands lines in a console it says that scene is not defined.
Example: bpy.ops.wm.context_set_int(data_path="scene.render.simplify_subdivision", value=2)
Bind this operator to a shortcut with different value and you'll be happy.
sorry, Im a new bie at programing in blender :D, I tried to create a class at the source script of scenes interface and when I call the operator it doesnt create a button in the panel so I cant put the shortcut. What am I doing wrong?
or you could indicate a reading material that could help me. :/
You shouldn't mistake this for a Blender support website. If Sergey or one of the other busy developers don't give you an answer, try blenderartists.org or better yet: http://blender.stackexchange.com/
Additionally, if I read Sergey's comment correctly, no scripting or programming is required. You can simply create a new hotkey assignment in the keymap, with the parameters he provided. Look up how to assign hotkeys if you're not familiar with this yet.
