Passes artifacts in Cycles when motion blur enabled #42143
2 Participants
Reference: blender/blender#42143
Windows 7 Ultimate 64 bit
i7
GTX 780 Ti
Also checked on GTX 770
Broken: 2.69, 2.71.3, 2.72
Worked: Don't know if it's a bug or a missing future
In Cycles, when the motion blur is enabled - Passes are rendered with artifacts, although the image render is fine.
It happens even when the render samples are high.
Blend file: Test_BUG_001.blend
Added subscriber: @SerjMaiorov
This is not a bug but a technical limitation. The
Index
pass is by its nature not mixable with results from other objects! This means that in areas where the object is half-transparent (motion blur) the index is either from the background or the object, but can only be one or the other.If you want to blend the object with the background you have other options, like using a material override or similar.
