Normal not displayed correctly in Material Viewport #42184
Reference: blender/blender#42184
win 8, 64; gtx 460 se
Blender 2.72 Hash:
95182d1
Normal node not displayed correctly in Material Viewport as same in the Rendered Viewport (check image attached and blend file)
Normal_Material_viewport_bug.blend
Added subscriber: @istoltoto
Same problem with all inputs from Texture Coordinate:Position, Normal; And Geometry:Generated, Normal, Object.
It's about cycles Render engine
However if you put the "Normal" input from Texture Coordinate in the Emitter, it works well.
The only problem is with "Normal Vector " having Outputs: Normal and Dot .
I hope you don't say it again: "Thanks for the report, but it's not currently considered a bug." :D
Added subscribers: @Sergey, @ThomasDinges, @MartijnBerger, @mont29
Sergey, Thomas, Martijn, any insight here?
Same with Mapping using Rotation with two axes like: X and Y is bad.
But i find a temporarily trick to displayed correctly: If you are using two Mapping, one with X and another with Y connected each other, then is displayed correctly.
That's likely an out-of-sync convention of geometry normal direction -- in Cycles it assumed to point outside, in BI it's assumed to point inside. Will need to have a closer look.
hello
Some news here?
This issue was referenced by
d9ddc99a27
Closed by commit
d9ddc99a27
