Linked lines only work with linked objects
Ubuntu 14.04 - AMD Mobility Radeon HD 4250
Broken: 2.72
Worked: 2.71
The lineset is linked from a file, the plates are linked from other file. The table and the holders are local.
I try resaving the /libreria/lineas.blend file with B2.72 (it was done on B2.71).
The file 000_0170_dieta.blend is a copy of a B2.71 file, resaved as B2.72 (it already had the lines linked).
/utileria/platos.blend file is B2.72, but the objects was appended froma B2.71 file and the modified.
2.71
2.72
Press F12 on file /episodios/0000_test/0000_017_dieta/0000_017_dieta.blend
Regards!
Gabriel Caraballo (eibriel) created this task.
Gabriel Caraballo (eibriel) raised the priority of this task from to Needs Triage by Developer.
This comment was removed by Campbell Barton (campbellbarton).
Hi,
I've been test the file, and it is confirmed. I'm on Ubuntu 14.04 64bit blender 2.72.1 858bf1a
FYI latest git master builds for Linux and Windows including the proposed fix are available through buildbots:
https://builder.blender.org/download/
Any further testing to check out the fix is much appreciated.
