"Menu Shadow Width" theme setting influences tooltip size #42221
Closed
opened 2014-10-14 18:05:26 +02:00 by Hadrien Brissaud · 11 comments
Win7x64 GTX660M
Broken: 2.72 release
When "Menu Shadow Width" is set to maximum (24), tooltip is shrinked to the point where it truncates content. Conversely, at 0 it creates a big margin around the tooltip.
**System Information** Win7x64 GTX660M **Blender Version** Broken: 2.72 release **Short description of error** When "Menu Shadow Width" is set to maximum (24), tooltip is shrinked to the point where it truncates content. Conversely, at 0 it creates a big margin around the tooltip. **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps
Added subscriber: @hadrien
Added subscriber: @JonathanWilliamson
I've confirmed this in 11e7679.
Menu Shadow Width: 0:
Menu Shadow Width: 12 (default):
Menu Shadow Width: 24:
I've confirmed this in 11e7679. **Menu Shadow Width: 0**: ![Screen_Shot_2014-10-14_at_1.47.01_PM.png](https://archive.blender.org/developer/F116700/Screen_Shot_2014-10-14_at_1.47.01_PM.png) **Menu Shadow Width: 12** (default): ![Screen_Shot_2014-10-14_at_1.47.05_PM.png](https://archive.blender.org/developer/F116698/Screen_Shot_2014-10-14_at_1.47.05_PM.png) **Menu Shadow Width: 24**: ![Screen_Shot_2014-10-14_at_1.47.10_PM.png](https://archive.blender.org/developer/F116699/Screen_Shot_2014-10-14_at_1.47.10_PM.png)
Julian Eisel self-assigned this 2014-10-14 22:59:07 +02:00
@JulianEisel, I've been digging into this a bit. It's a similar issue as #41548. It also causes problems with the Search Menu and seemingly any other pop-up menus/UIs. I believe this is due to each of them using the UI_ThemeMenuShadowWidth to define partially define the width and padding of the pop.
Are you aware of any reason why these would be using UI_ThemeMenuShadowWidth?
Lines 669-683 of interface_regions.c
	/* widget rect, in region coords */
		int width = UI_ThemeMenuShadowWidth();
		data->bbox.xmin = width;
		data->bbox.xmax = BLI_rcti_size_x(&rect_i) - width;
		data->bbox.ymin = width;
		data->bbox.ymax = BLI_rcti_size_y(&rect_i);
		/* region bigger for shadow */
		ar->winrct.xmin = rect_i.xmin - width;
		ar->winrct.xmax = rect_i.xmax + width;
		ar->winrct.ymin = rect_i.ymin - width;
		ar->winrct.ymax = rect_i.ymax + width;
Seems to me that the shadow width and padding width should be separately defined?
@JulianEisel, I've been digging into this a bit. It's a similar issue as #41548. It also causes problems with the Search Menu and seemingly any other pop-up menus/UIs. I believe this is due to each of them using the **UI_ThemeMenuShadowWidth** to define partially define the width and padding of the pop. Are you aware of any reason why these would be using UI_ThemeMenuShadowWidth? **Lines 669-683 of *interface_regions.c*** ``` /* widget rect, in region coords */ { int width = UI_ThemeMenuShadowWidth(); data->bbox.xmin = width; data->bbox.xmax = BLI_rcti_size_x(&rect_i) - width; data->bbox.ymin = width; data->bbox.ymax = BLI_rcti_size_y(&rect_i); /* region bigger for shadow */ ar->winrct.xmin = rect_i.xmin - width; ar->winrct.xmax = rect_i.xmax + width; ar->winrct.ymin = rect_i.ymin - width; ar->winrct.ymax = rect_i.ymax + width; } ``` Seems to me that the shadow width and padding width should be separately defined?
Member
We (@JonathanWilliamson and myself) talked a bit about this on IRC, but I should share it here, too, so...
The problem we have with the tooltip code is that it is a real mess. There are multiple rectangles to determine the sizes of text, background, padding, shadows, ... The biggest issue is that they depend on each other, quite weirdly, making it hard to do working changes. With the tooltip design update, I did some months ago, this only got worse, but since this was a much needed update, it was worth ignoring the added mess.
However, we could just try to fix this bug only (what would probably make the code worse again), or try to fix the complete system beneath it. I would much prefer the later one, as this would make further changes much, much easier.
I'd like to spend a bit of time on this tooltip code refactor and as I'm quite busy with other projects and the bug itself isn't that high priority (IMHO), I'll postpone it for a really few weeks.
Thanks a lot for the report @hadrien!
We (@JonathanWilliamson and myself) talked a bit about this on IRC, but I should share it here, too, so... The problem we have with the tooltip code is that it is a real mess. There are multiple rectangles to determine the sizes of text, background, padding, shadows, ... The biggest issue is that they depend on each other, quite weirdly, making it hard to do working changes. With the tooltip design update, I did some months ago, this only got worse, but since this was a much needed update, it was worth ignoring the added mess. However, we could just try to fix this bug only (what would probably make the code worse again), or try to fix the complete system beneath it. I would much prefer the later one, as this would make further changes much, much easier. I'd like to spend a bit of time on this tooltip code refactor and as I'm quite busy with other projects and the bug itself isn't that high priority (IMHO), I'll postpone it for a really few weeks. Thanks a lot for the report @hadrien!
I agree with you @JulianEisel, the latter method of refactoring the tooltip draw code is a better route. This is a low priority bug in my opinion that most people will never even encounter. Seems to me it's worth doing it right rather than just applying another bandage.
This issue was referenced by da31052b45
This issue was referenced by da31052b45b2d39582d175ff8f301c32c2a4ed1f
Closed by commit da31052b45.
5 Participants
Reference: blender/blender#42221
